Оптопары и оптореле Megawin
Datasheet TCR5RG (Toshiba) - 7
ПроизводительToshiba
ОписаниеUltra high Ripple rejection ratio, 500 mA CMOS Low Dropout Regulator in ultra small package
Страниц / Страница10 / 7 — TCR5RG series. 9. Application Note 9.1. Recommended Application Circuit. …
Формат / Размер файлаPDF / 483 Кб
TCR5RG series. 9. Application Note 9.1. Recommended Application Circuit. CONTROL. GND. VIN. OUT. 1 μF. 9.2. Power Dissipation. 1000. 800. (mW
TCR5RG series 9 Application Note 9.1 Recommended Application Circuit CONTROL GND VIN OUT 1 μF 9.2 Power Dissipation 1000 800 (mW
29 предложений от 7 поставщиков
Управление питанием (PMIC)
TCR5RG29A,LF
от 3.79 ₽
Зенер
Россия и страны ТС
TCR5RG29A,LF
от 10 ₽
Элитан
TCR5RG29A.LF
Toshiba
24 ₽
TCR5RG29A,LF
Toshiba
от 25 ₽
TCR5RG series 9. Application Note 9.1. Recommended Application Circuit CONTROL GND VIN V OUT 1 μF 1 μF
The figure above shows the recommended configuration for using a Low-Dropout regulator. Insert a capacitor at VOUT and VIN pins for stable input/output operation. (Ceramic capacitors can be used).
Board-mounted power dissipation ratings are available in the Absolute Maximum Ratings table. Power dissipation is measured on the board condition shown below. [The Board Condition] Board material: Glass epoxy (FR4) Board dimension: 40 mm x 40 mm (both sides of board), t = 1.6 mm Metal pattern ratio: a surface approximately 50 %, the reverse side approximately 50 % Through hole: diameter 0.5 mm x 24
1000 ) 800 (mW 600 ion PD pat 400 dissi er 200 Pow 0 −40 0 40 80 120 Ambient temperature Ta (°C)
© 2020 2020-12-18 Toshiba Electronic Devices & Storage Corporation
