Datasheet TSV7721, TSV7722, TSV7723 (STMicroelectronics) - 8
ПроизводительSTMicroelectronics
ОписаниеHigh bandwidth (22 MHz) low offset (200 μV) 5 V op amp
Страниц / Страница33 / 8 — TSV7721, TSV7722, TSV7723. Electrical characteristics
Формат / Размер файлаPDF / 4.5 Мб
TSV7721, TSV7722, TSV7723 Electrical characteristics
36 предложений от 9 поставщиков
Operational Amplifiers - Op Amps High bandwidth (22MHz) Low offset (200uV) 5V Op ampComplete Your Design
TSV7722IYST
87 ₽
TSV7722IYST
91 ₽
TSV7722IYST
от 102 ₽
TSV7722IYST
от 102 ₽
link to page 9
TSV7721, TSV7722, TSV7723 Electrical characteristics Table 5. Electrical characteristics at VCC+ = 1.8 V, with VCC- = 0 V, Vicm = 0.7 V, T = 25°C, and OUT pin connected to VCC / 2 through RL = 10 kΩ (unless otherwise specified) Symbol Parameter Conditions Min. Typ. Max. Unit DC Performance
T = 25°C ±50 ±250 Vio Input offset voltage (Vicm = 0 V) µV -40°C < T < 125°C ±650 ∆Vio/∆T Input offset voltage drift (Vicm = 0 V) -40°C < T < 125°C ±4 µV/°C T = 25°C 1 Iib Input bias current (VOUT = VCC/2) pA -40°C < T < 125°C 40 T = 25°C 1 Iio Input offset current (VOUT = VCC/2) pA -40°C < T < 125°C 15 Common-mode rejection ratio T = 25°C 72 93 CMR1 20.log(∆Vicm/∆Vio), Vicm = 0 V to dB -40°C < T < 125°C 68 VCC- 1.1 V, RL > 1 MΩ Common-mode rejection ratio T = 25°C 70 CMR2 20.log(∆Vicm/∆Vio), dB -40°C < T < 125°C 52 Vicm = - 0.1 V to VCC- 1.1 V, RL > 1 MΩ Large signal voltage gain V T = 25°C 101 122 A OUT = 0.3 V to VD dB (VCC- 0.3 V) -40°C < T < 125°C 97 High level output voltage T = 25°C 15 VOH (VOH = VCC - VOUT) -40°C < T < 125°C 25 mV T = 25°C 15 VOL Low level output voltage -40°C < T < 125°C 25 T = 25°C 35 42 Isink (VOUT = VCC) -40°C < T < 125°C 20 IOUT mA T = 25°C 20 32 Isource (VOUT = 0 V) -40°C < T < 125°C 10 Supply current (per channel, T = 25°C 1.7 2.2 ICC mA VOUT = VCC / 2, RL > 1 MΩ) -40°C < T < 125°C 2.5
AC Performance
GBW Gain bandwidth product 14 21 MHz Fu Unity gain frequency 18 Φm Phase margin CL = 47 pF 41 degrees Gm Gain margin 8 dB SR Slew rate (1) 7.6 11 V/µs f = 1 kHz 13 en Equivalent input noise voltage nV/√Hz f = 10 kHz 7 Channel separation CS f = 1 kHz 120 dB (for TSV7722 and TSV7723)
SHDN characteristics (TSV7723 only, SHDN active low)
Supply current per channel in shutdown T = 25°C 2.5 50 ICC nA mode VOUT = VCC / 2, RL > 1 MΩ, -40°C < T < 85°C 450
DS13614
Rev 1 page 8/33
Document Outline Features Applications Description 1 Pin connections 2 Absolute maximum ratings and operating conditions 3 Electrical characteristics 4 Typical performance characteristics 5 Application information 5.1 Operating voltages 5.2 Input offset voltage drift over the temperature 5.3 Unused channel 5.4 EMI rejection 5.5 Maximum power dissipation 5.6 Capacitive load and stability 5.7 Resistor values for high speed op amp design 5.8 Settling time 5.9 PCB layout recommendations 5.10 Decoupling capacitor 5.11 Macro model 6 Typical applications 6.1 Low-side current sensing 6.2 Photodiode transimpedance amplification 7 Package information 7.1 SOT23-5 package information 7.2 DFN8 2x2 package information 7.3 MiniSO8 package information 7.4 SO-8 package information 7.5 MiniSO10 package information 8 Ordering information Revision history
