Datasheet C2M0045170P (Wolfspeed) - 2
ПроизводительWolfspeed
ОписаниеSilicon Carbide Power MOSFET 1700 V 72 A 45 mΩ
Страниц / Страница10 / 2 — Electrical Characteristics. Symbol. Parameter. Min. Typ. Max. Unit. Test …
Electrical Characteristics. Symbol. Parameter. Min. Typ. Max. Unit. Test Conditions. Note. Reverse Diode Characteristics
Electrical Characteristics Symbol Parameter Min Typ Max Unit Test Conditions Note Reverse Diode Characteristics
13 предложений от 8 поставщиков
, Silicon Carbide Power MOSFET C2M MOSFET Technology
C2M0045170P
6 073 ₽
C2M0045170P
Wolfspeed
от 6 526 ₽
C2M0045170P
Yageo
от 15 304 ₽
Hi-Tech Circuit Group
C2M0045170P
Wolfspeed
(T = 25˚C unless otherwise specified) C
Symbol Parameter Min. Typ. Max. Unit Test Conditions Note
V(BR)DSS Drain-Source Breakdown Voltage 1700 V VGS = 0 V, ID = 100 μA 2.0 2.6 4 V V V DS = VGS, ID = 18mA GS(th) Gate Threshold Voltage Fig. 11 1.8 V VDS = VGS, ID = 18mA, TJ = 150 °C IDSS Zero Gate Voltage Drain Current 2 100 μA VDS = 1700 V, VGS = 0 V IGSS Gate-Source Leakage Current 600 nA VGS = 20 V, VDS = 0 V 45 59 V R GS = 20 V, ID = 50 A Fig. DS(on) Drain-Source On-State Resistance mΩ 4,5,6 90 VGS = 20 V, ID = 50 A, TJ = 150 °C 21.7 V g DS= 20 V, IDS= 50 A fs Transconductance S Fig. 7 24.4 VDS= 20 V, IDS= 50 A, TJ = 150 °C Ciss Input Capacitance 3672 VGS = 0 V Coss Output Capacitance 171 pF Fig. VDS = 1000 V 17,18 Crss Reverse Transfer Capacitance 6.7 f = 1 MHz VAC = 25 mV Eoss Coss Stored Energy 105 μJ Fig 16 E V ON Turn-On Switching Energy (SiC Diode FWD) 0.67 DS = 1200 V, VGS = -5/20 V, mJ Fig. 26, I = 50A, R = 2.5Ω, L= 105 μH, D G(ext) 29b EOFF Turn Off Switching Energy (SiC Diode FWD) 0.31 TJ = 150 °C, using SiC Diode as FWD E V ON Turn-On Switching Energy (Body Diode FWD) 2.8 DS = 1200 V, VGS = -5/20 V, mJ Fig. 26, I = 50A, R = 2.5Ω, L= 105 μH, D G(ext) 29a EOFF Turn Off Switching Energy (Body Diode FWD) 0.35 TJ = 150 °C, using MOSFET as FWD td(on) Turn-On Delay Time 35 VDD = 1200 V, VGS = -5/20 V t ID = 50 A, r Rise Time 13 ns R Fig. 27, G(ext) = 2.5 Ω, Timing relative to V DS 29 td(off) Turn-Off Delay Time 46 Inductive load tf Fall Time 10 RG(int) Internal Gate Resistance 1.3 Ω f = 1 MHz, VAC = 25 mV Qgs Gate to Source Charge 44 VDS = 1200 V, VGS = -5/20 V Qgd Gate to Drain Charge 57 nC ID = 50 A Fig. 12 Per IEC60747-8-4 pg 21 Qg Total Gate Charge 188
Reverse Diode Characteristics Symbol Parameter Typ. Max. Unit Test Conditions Note
4.1 V V = - 5 V, I = 25 A Fig. 8, 9, V GS SD SD Diode Forward Voltage 10 3.6 V V = - 5 V, I = 25 A, T = 150 °C Note 1 GS SD J IS Continuous Diode Forward Current 72 A T = 25 °C, V = - 5 V Note 1 C GS t Reverse Recovery Time 44 ns rr V = - 5 V, I = 50 A , V = 1200 V GS SD R Q Reverse Recovery Charge 2 µC rr dif/dt = 3000 A/µs Note 1 I Peak Reverse Recovery Current 60 A rrm Note (1): When using SiC Body Diode the maximum recommended V = -5V GS
Thermal Characteristics Symbol Parameter Typ. Max. Unit Test Conditions Note
RθJC Thermal Resistance from Junction to Case 0.22 0.24 Fig. 21 °C/W RθJC Thermal Resistance from Junction to Ambient 40
2
C2M0045170P Rev. -, 04-2018
