Datasheet MM5130 (Menlo Micro) - 3
ПроизводительMenlo Micro
ОписаниеDC to 26 GHz High Power RF Switch
Страниц / Страница22 / 3 — v2.0. Table 2. Parameter. Minimum. Typical. Maximum. Unit. Operating …
v2.0. Table 2. Parameter. Minimum. Typical. Maximum. Unit. Operating Frequency Range. CW Power @ 6 GHz3. Peak Power @ 6 GHz4
v2.0 Table 2 Parameter Minimum Typical Maximum Unit Operating Frequency Range CW Power @ 6 GHz3 Peak Power @ 6 GHz4
10 предложений от 3 поставщиков
Зенер
Россия и страны ТС
MM5130-03NDB-TRот 7 315 ₽
MM5130-03NDB-TRот 15 103 ₽
Элитан
MM5130-03NDB-TR17 953 ₽
3 MM5130 – DC to 26 GHz High Power RF Switch | March 24, 2021
v2.0 Table 2
DC and AC Electrical Specifications All specifications valid over full VBB range and full operating temperature range unless otherwise noted.
Normal SP4T mode DC 18 GHz Super-port mode DC 26 GHz
CW Power @ 6 GHz3
25 W
Peak Power @ 6 GHz4
150 W
Insertion Loss
Normal SP4T mode @ 6 GHz 0.4 Super-port mode @ 6 GHz 0.4 Normal SP4T mode @ 18 GHz 1.3 dB Super-port mode @ 18 GHz 0.8 Normal SP4T mode @ 26 GHz -- Super-port mode @ 26 GHz
5
1.0
Input / Output Return Loss
Normal SP4T mode @ 6 GHz 15 Super-port mode @ 6 GHz 15 Normal SP4T mode @ 18 GHz 10 dB Super-port mode @ 18 GHz 18 Normal SP4T mode @ 26 GHz -- Super-port mode @ 26 GHz
5
20
Isolation
Normal SP4T mode @ 6 GHz 25 Super-port mode @ 6 GHz 45 Normal SP4T mode @ 18 GHz 18 dB Super-port mode @ 18 GHz 32 Normal SP4T mode @ 26 GHz -- Super-port mode @ 26 GHz
5
22
Channel to Channel Isolation @ 6 GHz
25 dB 3 Measured at +85ºC. 4 For 10 % Duty Cycle and 10 µs pulse width, measured at +85ºC. 5 Measured on non-adjacent paths, see measured data for details. © 2020 Menlo Microsystems, Inc. | All Rights Reserved | www.menlomicro.com
