Datasheet 1N914 (Vishay) - 2
ПроизводительVishay
ОписаниеSmall Signal Fast Switching Diodes
Страниц / Страница3 / 2 — 1N914. ELECTRICAL CHARACTERISTICS. PARAMETER. TEST CONDITION. SYMBOL. …
Версия01-Jan-2021
Формат / Размер файлаPDF / 71 Кб
1N914. ELECTRICAL CHARACTERISTICS. PARAMETER. TEST CONDITION. SYMBOL. MIN. TYP. MAX. UNIT. TYPICAL CHARACTERISTICS. PACKAGE DIMENSIONS
1N914 ELECTRICAL CHARACTERISTICS PARAMETER TEST CONDITION SYMBOL MIN TYP MAX UNIT TYPICAL CHARACTERISTICS PACKAGE DIMENSIONS
38 предложений от 13 поставщиков
Диоды - общего назначения, управление питанием, коммутация 100 Volt 300mA
1N914TAP
от 0.76 ₽
1N914TAP
13 ₽
1N914TAP
15 ₽
Hi-Tech Circuit Group
1N914TAP
1N914
www.vishay.com Vishay Semiconductors
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT
Forward voltage IF = 10 mA VF 1 V Breakdown voltage IR = 100 μA V(BR) 100 V VR = 75 V IR 5 μA Peak reverse current VR = 20 V, Tj = 150 °C IR 50 μA VR = 20 V IR 25 nA Diode capacitance VR = 0, f = 1 MHz CD 4 pF I Reverse recovery time F = 10 mA, iR = 1 mA, VR = 6 V, RL = 100 Ω trr 4 ns
(Tamb = 25 °C, unless otherwise specified) 1000 1000 1N914 100 T = 25 °C j 100 Scattering Limit 10 Scattering Limit 10 1 - Forward Current (mA) - Reverse Current (nA) I F I R T = 25 °C j 0.1 1 0 0.4 0.8 1.2 1.6 2.0 10 1 100 94 9170_1 V 94 9098 V - Reverse Voltage (V) F - Forward Voltage (V) R Fig. 1 - Forward Current vs. Forward Voltage Fig. 2 - Reverse Current vs. Reverse Voltage
PACKAGE DIMENSIONS
in millimeters (inches):
DO-35 (DO-204AH)
Cathode Identification ] ] 24] 7 0 .0 .015] 6 5 [0 .0 .0 [0 26 min. [1.024] 3.9 max. [0.154] 26 min. [1.024] 0 0 x. [ [ a in. 7 3 1. 1. 3.1 min. [0.120] 6 m 4 m 0. 0. Ø Ø Rev. 6 - Date: 19. December 2011 Document no.: SB-V-3906.04-031(4) 94 9366 Rev. 2.0, 24-Feb-2020
2
Document Number: 85622 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
