Линейка продуктов KEEN SIDE
Datasheet SD101A, SD101B, SD101C (Vishay) - 2
ПроизводительVishay
ОписаниеSmall Signal Schottky Diodes
Страниц / Страница4 / 2 — SD101A, SD101B, SD101C. ELECTRICAL CHARACTERISTICS. PARAMETER. TEST …
Формат / Размер файлаPDF / 78 Кб
SD101A, SD101B, SD101C. ELECTRICAL CHARACTERISTICS. PARAMETER. TEST CONDITION. PART. SYMBOL. MIN. TYP. MAX. UNIT. TYPICAL CHARACTERISTICS
SD101A, SD101B, SD101C ELECTRICAL CHARACTERISTICS PARAMETER TEST CONDITION PART SYMBOL MIN TYP MAX UNIT TYPICAL CHARACTERISTICS
27 предложений от 10 поставщиков
Диоды и выпрямители Шоттки 1mA 50 Volt
SD101B-TR
от 3.28 ₽
Эиком
SD101B-TR
от 8.40 ₽
SD101B-TR
29 ₽
727GS
SD101B-TR
от 36 ₽
www.vishay.com Vishay Semiconductors
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION PART SYMBOL MIN. TYP. MAX. UNIT
SD101A V(BR) 60 V Reverse breakdown voltage IR = 10 μA SD101B V(BR) 50 V SD101C V(BR) 40 V VR = 50 V SD101A IR 200 nA Leakage current VR = 40 V SD101B IR 200 nA VR = 30 V SD101C IR 200 nA SD101A VF 410 mV IF = 1 mA SD101B VF 400 mV SD101C VF 390 mV Forward voltage drop SD101A VF 1000 mV IF = 15 mA SD101B VF 950 mV SD101C VF 900 mV SD101A CD 2.0 pF Diode capacitance VR = 0 V, f = 1 MHz SD101B CD 2.1 pF SD101C CD 2.2 pF
(Tamb = 25 °C, unless otherwise specified) 100 10.00 T = 125 °C j 10 T = 100 °C 1.00 j rrent (mA) u 1 T = 75 °C j e Current (μA) s ard C T = 50 °C w j 0.10 - Rever 0.1 - For I R I F T = 25 °C j 0.01 0.01 0 5 10 15 20 25 30 35 40 45 50 0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 16204 V - Reverse Voltage (V) 16206 V - Forward Voltage (V) R F Fig. 1 - Reverse Current vs. Reverse Voltage Fig. 3 - Forward Current vs. Forward Voltage 2.0 1.8 T = 25 °C j 1.6 1.4 1.2 1.0 0.8 0.6 - Diode Capacitance (pF) D 0.4 C 0.2 0.0 0 5 10 15 20 25 30 35 40 45 50 16205 V - Reverse Voltage (V) R Fig. 2 - Diode Capacitance vs. Reverse Voltage Rev. 1.8, 01-Jun-17
2
Document Number: 85629 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
