Оптопары и оптореле Megawin
Datasheet SD101AW, SD101BW, SD101CW (Vishay) - 2
ПроизводительVishay
ОписаниеSmall Signal Schottky Diodes
Страниц / Страница4 / 2 — SD101AW, SD101BW, SD101CW. ELECTRICAL CHARACTERISTICS. PARAMETER. TEST …
Формат / Размер файлаPDF / 93 Кб
SD101AW, SD101BW, SD101CW. ELECTRICAL CHARACTERISTICS. PARAMETER. TEST CONDITION. PART. SYMBOL. MIN. TYP. MAX. UNIT
SD101AW, SD101BW, SD101CW ELECTRICAL CHARACTERISTICS PARAMETER TEST CONDITION PART SYMBOL MIN TYP MAX UNIT
34 предложений от 12 поставщиков
SD101AW-E3-08
от 1.80 ₽
Эиком
SD101AW-E3-08
от 13 ₽
SD101AW-E3-08
от 13 ₽
727GS
SD101AW-E3-08
от 64 ₽
www.vishay.com Vishay Semiconductors
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION PART SYMBOL MIN. TYP. MAX. UNIT
SD101AW V(BR) 60 V Reverse breakdown voltage IR = 10 μA SD101BW V(BR) 50 V SD101CW V(BR) 40 V VR = 50 V SD101AW IR 200 nA Leakage current VR = 40 V SD101BW IR 200 nA VR = 30 V SD101CW IR 200 nA SD101AW VF 410 mV IF = 1 mA SD101BW VF 400 mV SD101CW VF 390 mV Forward voltage drop SD101AW VF 1000 mV IF = 15 mA SD101BW VF 950 mV SD101CW VF 900 mV SD101AW CD 2 pF Diode capacitance VR = 0 V, f = 1 MHz SD101BW CD 2.1 pF SD101CW CD 2.2 pF Reverse recovery time IF = IR = 5 mA, recover to 0.1 IR trr 1 ns
TYPICAL CHARACTERISTICS
(Tamb = 25 °C, unless otherwise specified) 10 100 A B 125 °C C 10 (µA) 100 °C (mA) 1 Current 1 75 °C Current 0.1 50 °C Reverse 0.1 Forward - I R I - F 25 °C 0.01 0.01 0 0.2 0.4 0.6 0.8 1.0 0 10 20 30 40 50 18479 V 18477 VF - Forward Voltage (V) R - Reverse Voltage (V) Fig. 1 - Typical Variation of Forward Current vs. Forward Voltage Fig. 3 - Typical Variation of Reverse Current at Various Temperatures 100 2.0 A Tj = 25 °C B 1.8 C 80 1.6 1.4 60 1.2 A B C 1.0 apacitance (pF) C 40 0.8 0.6 Forward Current (mA) Typical - F 20 0.4 I - D C 0.2 0 0 0 0.2 0.4 0.6 0.8 1.0 0 10 20 30 40 50 18478 VF - Forward Voltage (V) 18480 VR - Reverse Voltage (V) Fig. 2 - Typical Forward Conduction Curve Fig. 4 - Typical Capacitance Curve as a Function of Reverse Voltage Rev. 1.9, 23-Feb-18
2
Document Number: 85679 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
