Datasheet MAX4373, MAX4374, MAX4375 (Maxim) - 2
ПроизводительMaxim
ОписаниеLow-Cost, Micropower, High-Side Current-Sense Amplifier + Comparator + Reference ICs
Страниц / Страница13 / 2 — Absolute Maximum Ratings. Electrical Characteristics. PARAMETER. SYMBOL. …
Формат / Размер файлаPDF / 302 Кб
Absolute Maximum Ratings. Electrical Characteristics. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS
Absolute Maximum Ratings Electrical Characteristics PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
37 предложений от 19 поставщиков
Микросхема Буферный усилитель, MAXIM INTEGRATED PRODUCTS MAX4374TEUB+ Current Sense Amplifier, High Side, Micropower, 1 Amplifier, 2.5μA, µMAX, 10Pins, -40℃, 85℃
727GS
MAX4374TEUB+T
Maxim
от 85 ₽
Зенер
Россия и страны ТС
MAX4374TEUB+T
Maxim
от 148 ₽
MAX4374TEUB-TG069
180 ₽
MAX4374TEUB
от 344 ₽
MAX4373/MAX4374/MAX4375 Low-Cost, Micropower, High-Side Current-Sense Amplifier + Comparator + Reference ICs
VCC, RS+, RS- to GND ...-0.3V to +30V Continuous Power Dissipation (TA = +70°C) OUT to GND ..-0.3V to the lesser of 8-Pin µMAX (derate 4.1mW/°C above +70°C) ...330mW (VCC + 0.3V) or +15V 8-Pin SO (derate 5.9mW/°C above +70°C)..471mW CIN1, CIN2, RESET to GND ..-0.3V to the lesser of 10-Pin µMAX (derate 5.6mW/°C above +70°C) ...444mW (VCC + 0.3V) or +12V 14-Pin SO (derate 8.3mW/°C above +70°C)..667mW Differential Input Voltage (VRS+ - VRS-) ..±0.3V Operating Temperature Range ...-40°C to +85°C COUT1, COUT2 to GND..-0.3V to +6.0V Junction Temperature ..+150°C Current into Any Pin..±10mA Storage Temperature Range ...-65°C to +150°C Lead Temperature (soldering, 10s) ...+300°C Soldering Temperature (reflow) ...+260°C Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
(VCC = +2.7V to +28V, VRS+ = 0 to +28V, VSENSE = 0V, VRESET = 0V, RLOAD= 1MΩ, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1)
Operating Voltage Range VCC 2.7 28 V (Note 2) Common-Mode Input Range VCMR 0 28 V (Note 3) Common-Mode Rejection CMR VRS+ > 2V 85 dB Supply Current ICC VRS+ > 2V, VSENSE = 5mV 50 100 µA Leakage Current IRS+, IRS- VCC = 0V, VRS+ = 28V ±0.015 ±0.5 µA VRS+ > 2V 0 2.5 IRS+ VRS+ ≤ 2V -25 2.0 Input Bias Current µA VRS+ > 2V 0 4 IRS- VRS+ ≤ 2V -50 4 Full-Scale Sense Voltage Gain = +20V/V, +50V/V, VRS+ = 12V 150 170 V mV (Note 4) SENSE Gain = +100V/V, VRS+ = 12V 100 120 V TA = +25°C 0.1 1 CC = VRS+ = 12V Input Offset Voltage VOS mV (Note 11) TA = TMIN to TMAX 2 T V A = +25°C ±0.30 ±2 CC = 12V, V V RS+ = 12V TA = TMIN to TMAX ±3 SENSE = 100mV TA = +25°C ±0.35 ±2 VCC = 28V, Total OUT Voltage Error (Note 6) V V RS+ = 28V OUT TA = TMIN to TMAX ±3 % (Note 5) VCC = 12V, VRS+ = 0.1V ±5.0 VSENSE = 6.25mV, VCC = 12V, ±5.0 VRS+ = 12V (Note 7) I V OUT = 10µA 2.5 OUT Voltage Low V CC = 2.7V, OUT mV VRS+ = 12V IOUT = 100µA 8.5 65 VCC - OUT Voltage High VCC = 2.7V, IOUT = -500µA, VRS+ = 12V 0.25 V VOH www.maximintegrated.com Maxim Integrated | 2
