Datasheet MAX4373, MAX4374, MAX4375 (Maxim) - 3
ПроизводительMaxim
ОписаниеLow-Cost, Micropower, High-Side Current-Sense Amplifier + Comparator + Reference ICs
Страниц / Страница13 / 3 — Electrical Characteristics (continued). PARAMETER. SYMBOL. CONDITIONS. …
Формат / Размер файлаPDF / 302 Кб
Electrical Characteristics (continued). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. COMPARATOR
Electrical Characteristics (continued) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS COMPARATOR
Микросхема Буферный усилитель, Sense Amplifier and Comparator 14Pin SOIC N T/R
MAX4374HESD+T
Maxim
58 ₽
MAX4374HESD+T
Maxim
149 ₽
MAX4374HESD+T
Maxim
182 ₽
МосЧип
MAX4374HESD-T
Maxim
MAX4373/MAX4374/MAX4375 Low-Cost, Micropower, High-Side Current-Sense Amplifier + Comparator + Reference ICs
(VCC = +2.7V to +28V, VRS+ = 0 to +28V, VSENSE = 0V, VRESET = 0V, RLOAD= 1MΩ, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1)
VSENSE = 100mV, 200 Gain = +20V/V VSENSE = 100mV, 120 Gain = +50V/V -3dB Bandwidth BW kHz VRS+ = 12V, VCC = 12V, VSENSE = 100mV, 110 CLOAD = 10pF Gain = +100V/V VSENSE = 6.25mV 50 MAX437_T +20 Gain AV MAX437_F +50 V/V MAX437_H +100 VSENSE = TA = +25°C ±0.3 ±1.7 20mV to 150mV; VCC = 12V; VRS+ = TA = -40°C to +85°C ±2.7 12V; Gain = 20, 50 Gain Accuracy ΔAV % VSENSE = TA = +25°C ±0.3 ±1.7 20mV to 100mV, VCC = 12V, VRS+ = TA = -40°C to +85°C ±2.7 12V, Gain = 100 Gain = +20V/V, VSENSE = 6.25mV to 20 100mV OUT Settling Time to 1% of VCC = 12V, µs Final Value VRS+ = 12V, VSENSE = 100mV to 20 CLOAD = 10pF 6.25mV Capacitive Load Stability No sustained oscillations 1000 pF OUT Output Resistance ROUT VSENSE = 100mV 1.5 Ω Power-Supply Rejection PSR VOUT = 2V, VRS+ > 2V 72 87 dB Power-Up Time to 1% of Final VSENSE = 100mV, CLOAD = 10pF, 0.5 ms Value VCC = 12V, VRS+ = 12V Saturation Recovery Time VCC = 12V, VRS+ = 12V, CLOAD = 10pF 0.1 ms (Note 8)
COMPARATOR
(Note 9) TA = +25°C 590 600 610 Comparator Threshold VTH mV TA = TMIN to TMAX 586 614 Comparator Hysteresis -9 mV Input Bias Current IB ±2.2 ±15 nA C Propagation Delay L = 10pF, RL = 10kΩ pull-up to 5V, 4 µs 5mV of overdrive Output Low Voltage VOL ISINK = 1mA 0.6 V www.maximintegrated.com Maxim Integrated | 3
