Datasheet MAX4373, MAX4374, MAX4375 (Maxim) - 5
ПроизводительMaxim
ОписаниеLow-Cost, Micropower, High-Side Current-Sense Amplifier + Comparator + Reference ICs
Страниц / Страница13 / 5 — Typical Operating Characteristics (continued). TOTAL OUTPUT ERROR. vs. …
Формат / Размер файлаPDF / 302 Кб
Typical Operating Characteristics (continued). TOTAL OUTPUT ERROR. vs. SUPPLY VOLTAGE. vs. SENSE VOLTAGE
Typical Operating Characteristics (continued) TOTAL OUTPUT ERROR vs SUPPLY VOLTAGE vs SENSE VOLTAGE
22 предложений от 17 поставщиков
Микросхема Буферный усилитель, Sense Amplifier and Comparator 14Pin SOIC N
MAX4374HESD+T
Maxim
144 ₽
MAX4374HESD
Maxim
172 ₽
MAX4374HESD+
Maxim
от 185 ₽
ТаймЧипс
MAX4374HESD
Maxim
MAX4373/MAX4374/MAX4375 Low-Cost, Micropower, High-Side Current-Sense Amplifier + Comparator + Reference ICs
(VRS+ = +12V, VCC = +12V, RLOAD = 1MΩ, VRESET = 0V, VSENSE = 100mV, VPULL-UP = +5V, RPULL-UP = 10kΩ, TA = +25°C, unless otherwise noted.)
TOTAL OUTPUT ERROR TOTAL OUTPUT ERROR TOTAL OUTPUT ERROR vs. SUPPLY VOLTAGE vs. SENSE VOLTAGE vs. SENSE VOLTAGE
5 1.5 2.0 4 VCC = +5.5V 1.0 1.5 3 A MAX4373 toc04 A V = +50V/V V = +100V/V MAX4373 toc05 MAX4373 toc06 0.5 1.0 2 A A V = +100V/V V = +100V/V AV = +20V/V 1 0 A 0.5 V = +20V/V 0 AV = +20V/V -0.5 0 -1 -1.0 -0.5 AV = +50V/V OUTPUT ERROR (%) -2 OUTPUT ERROR (%) AV = +50V/V OUTPUT ERROR (%) -1.5 -1.0 -3 -4 -2.0 -1.5 VSENSE = 6.25mV -5 -2.5 -2.0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 0 25 50 75 100 125 150 0 25 50 75 100 125 150 SUPPLY VOLTAGE (V) VSENSE (mV) VSENSE (mV)
TOTAL OUTPUT ERROR TOTAL OUTPUT ERROR vs. SENSE VOLTAGE vs. COMMON-MODE VOLTAGE
3.0 12 VCC = +28V 10 2.5 MAX4373 toc07 MAX4373 toc08 AV = +100V/V 8 AV = +100V/V 2.0 6 AV = +50V/V 1.5 4 OUTPUT ERROR (%) 1.0 AV = +20V/V OUTPUT ERROR (%) AV = +50V/V 2 0.5 0 AV = +20V/V 0 -2 0 25 50 75 100 125 150 2 4 6 8 10 12 14 16 18 20 22 24 26 28 VSENSE (mV) COMMON-MODE VOLTAGE (V)
SMALL-SIGNAL PULSE RESPONSE SMALL-SIGNAL PULSE RESPONSE SMALL-SIGNAL PULSE RESPONSE (AV = +20V/V) (AV = +50V/V) (AV = +100V/V)
MAX4373 toc09 MAX4373 toc10 MAX4373 toc11 30mV 30mV 30mV INPUT INPUT INPUT 10mV 10mV 10mV 600mV 1.5V 3V OUTPUT OUTPUT OUTPUT 200mV 500mV 1V 20μs/div 20μs/div 20μs/div www.maximintegrated.com Maxim Integrated | 5
