Datasheet L200 (STMicroelectronics) - 4
ПроизводительSTMicroelectronics
ОписаниеAdjustable Voltage and Current Regulator
Страниц / Страница12 / 4 — L200. ELECTRICAL CHARACTERISTICS. Symbol. Parameter. Test Conditions. …
Формат / Размер файлаPDF / 254 Кб
L200. ELECTRICAL CHARACTERISTICS. Symbol. Parameter. Test Conditions. Min. Typ. Max. Unit. CURRENT REGULATION LOOP
L200 ELECTRICAL CHARACTERISTICS Symbol Parameter Test Conditions Min Typ Max Unit CURRENT REGULATION LOOP
(continued)
Symbol Parameter Test Conditions Min. Typ. Max. Unit
∆Vref Average Temperature Coefficient Vi = 20 V Io = 10mA of Reference Voltage for Tj = - 25 to 125 °C -0.25 mV/°C for Tj = 125 to 150 °C -1.5 mV/°C I4 Bias Current and Pin 4 3 10 µA ∆ I Average Temperature -0.5 %/°C 4 ∆ T • I4 Coefficient (pin 4) Zo Output Impedance Vi = 10 V Vo = Vref Io = 0.5 A f = 100 Hz 1.5 mΩ
VSC Current Limit Sense Voltage Vi = 10 V Vo = Vref between Pins 5 and 2 I5 = 100 mA 0.38 0.45 0.52 V ∆ VSC Average Temperature 0.03 %/°C ∆ T • V Coefficient of VSC SC ∆ Io Current Load Regulation Vi = 10 V ∆Vo = 3V I I 1.4 % o o = 0.5 A Io = 1A 1 % Io = 1.5 A 0.9 % ISC Peak Short Circuit Current Vi - V0 = 14 V (pins 2 and 5 short circuited) 3.6 A Note 1: A load step of 2 A can be applied provited that input-output differential voltage is lower than 20 V (see Figure 3). Note 2: The same performance can be maintained at higher output levels if a bypassing capacitor is provited between pins 2 and 4.
Figure 3. Typical Safe Operating Area Figure 4. Quiescent Current vs. Supply Protection. Voltage.
4/12
