Datasheet MAX1771 (Maxim) - 2
ПроизводительMaxim
Описание12V or Adjustable, High-Efficiency, Low IQ, Step-Up DC-DC Controller
Страниц / Страница16 / 2 — 12V or Adjustable, High-Efficiency, Low IQ, Step-Up DC-DC Controller. …
Формат / Размер файлаPDF / 782 Кб
12V or Adjustable, High-Efficiency, Low IQ, Step-Up DC-DC Controller. ABSOLUTE MAXIMUM RATINGS. ELECTRICAL CHARACTERISTICS
12V or Adjustable, High-Efficiency, Low IQ, Step-Up DC-DC Controller ABSOLUTE MAXIMUM RATINGS ELECTRICAL CHARACTERISTICS
75 предложений от 27 поставщиков
ЧипСити
MAX1771ESA+T
Maxim
103 ₽
Рутоника
MAX1771ESA+T
Maxim
258 ₽
Зенер
Россия и страны ТС
MAX1771ESA+T
Maxim
от 393 ₽
MAX1771ESA+T
Maxim
MAX1771
Supply Voltage Operating Temperature Ranges V+ to GND ...-0.3V, 17V MAX1771C_ A ...0°C to +70°C EXT, CS, REF, SHDN, FB to GND ...-0.3V, (V+ + 0.3V) MAX1771E_ A ..-40°C to +85°C GND to AGND...0.1V, -0.1V MAX1771MJA ..-55°C to +125°C Continuous Power Dissipation (TA = +70°C) Junction Temperatures Plastic DIP (derate 9.09mW/°C above +70°C) ..727mW MAX1771C_ A/E_ A...+150°C SO (derate 5.88mW/°C above +70°C) ...471mW MAX1771MJA ..+175°C CERDIP (derate 8.00mW/°C above +70°C) ...640mW Storage Temperature Range ...-65°C to +160°C Lead Temperature (soldering, 10sec) ...+300°C Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
(V+ = 5V, ILOAD = 0mA, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX1771 (internal feedback resistors) 2.0 12.5 Input Voltage Range MAX1771C/E (external resistors) 3.0 16.5 V MAX1771MJA (external resistors) 3.1 16.5 Minimum Start-Up Voltage 1.8 2.0 V Supply Current V+ = 16.5V, SHDN = 0V (normal operation) 85 110 µA V+ = 10V, SHDN ≥ 1.6V (shutdown) 2 5 Standby Current µA V+ = 16.5V, SHDN ≥ 1.6V (shutdown) 4 V+ = 2V to 12V, over full load range, Output Voltage (Note 1) 11.52 12.0 12.48 V Circuit of Figure 2a Output Voltage Line Regulation V+ = 5V to 7V, VOUT = 12V 5 mV/V (Note 2) ILOAD = 700mA, Circuit of Figure 2a Output Voltage Load Regulation V+ = 6V, VOUT = 12V, ILOAD = 0mA to 20 mV/A (Note 2) 500mA, Circuit of Figure 2a Maximum Switch On-Time tON(max) 12 16 20 µs Minimum Switch Off-Time tOFF(min) 1.8 2.3 2.8 µs V+ = 5V, VOUT = 12V, ILOAD = 500mA, Efficiency 92 % Circuit of Figure 2a MAX1771C 1.4700 1.5 1.5300 Reference Voltage VREF IREF = 0µA MAX1771E 1.4625 1.5 1.5375 V MAX1771M 1.4550 1.5 1.5450 MAX1771C/E 4 10 REF Load Regulation 0µA ≤ IREF ≤ 100µA mV MAX1771M 4 15 REF Line Regulation 3V ≤ V+ ≤ 16.5V 40 100 µV/V MAX1771C 1.4700 1.5 1.5300 FB Trip Point Voltage VFB MAX1771E 1.4625 1.5 1.5375 V MAX1771M 1.4550 1.5 1.5450 2 Maxim Integrated
