Datasheet MC10EL31, MC100EL31 (ON Semiconductor) - 4
ПроизводительON Semiconductor
Описание5 V ECL D Flip‐Flop with Set and Reset
Страниц / Страница8 / 4 — MC10EL31, MC100EL31. Table 7. 100EL SERIES NECL DC CHARACTERISTICS. −40. …
Версия8
Формат / Размер файлаPDF / 200 Кб
MC10EL31, MC100EL31. Table 7. 100EL SERIES NECL DC CHARACTERISTICS. −40. Symbol. Characteristic. Min. Typ. Max. Unit
MC10EL31, MC100EL31 Table 7 100EL SERIES NECL DC CHARACTERISTICS −40 Symbol Characteristic Min Typ Max Unit
37 предложений от 20 поставщиков
Микросхема Бистабильный мульти, MC100EL31 Series 2.8GHz 5.7V ECL D Flip-Flop With Set and Reset - SOIC-8
MC100EL31DG
550 ₽
Зенер
Россия и страны ТС
MC100EL31DG
от 917 ₽
Элитан
MC100EL31DG
1 128 ₽
MC100EL31DG
link to page 4 link to page 4 link to page 4 link to page 4
MC10EL31, MC100EL31 Table 7. 100EL SERIES NECL DC CHARACTERISTICS
(VCC = 0 V; VEE = −5.0 V (Note 1))
−40
C 25
C 85
C Symbol Characteristic Min Typ Max Min Typ Max Min Typ Max Unit
IEE Power Supply Current 27 32 27 32 31 37 mA VOH Output HIGH Voltage (Note 2) −1085 −1005 −880 −1025 −955 −880 −1025 −955 −880 mV VOL Output LOW Voltage (Note 2) −1830 −1695 −1555 −1810 −1705 −1620 −1810 −1705 −1620 mV VIH Input HIGH Voltage −1165 −880 −1165 −880 −1165 −880 mV VIL Input LOW Voltage −1810 −1475 −1810 −1475 −1810 −1475 mV IIH Input HIGH Current 150 150 150 mA IIL Input LOW Current 0.5 0.5 0.5 mA NOTE: Device will meet the specifications after thermal equilibrium has been established when mounted in a test socket or printed circuit board with maintained transverse airflow greater than 500 lfpm. 1. Input and output parameters vary 1:1 with VCC. VEE can vary +0.8 V / −0.5 V. 2. Outputs are terminated through a 50 ohm resistor to VCC−2 volts.
Table 8. AC CHARACTERISTICS
(VCC = 5.0 V; VEE = 0 V or VCC = 0 V; VEE = −5.0 V (Note 1))
−40
C 25
C 85
fmax Maximum Toggle Frequency 2.0 2.5 2.2 2.8 2.2 2.8 GHz tPLH Propagation Delay ps tPHL to Output CLK 315 465 630 375 475 590 430 530 645 S, R 295 455 630 355 465 590 400 510 645 tS Setup Time 150 0 150 0 150 0 ps tH Hold Time 250 100 250 100 250 100 tRR Set/Reset Recovery 400 200 400 200 400 200 ps tPW Minimum Pulse Width ps CLK, Set, Reset 400 400 400 tJITTER Cycle-to-Cycle Jitter TBD TBD TBD ps tr Output Rise/Fall Times Q 100 225 350 100 225 350 100 225 350 ps tf (20% − 80%) NOTE: Device will meet the specifications after thermal equilibrium has been established when mounted in a test socket or printed circuit board with maintained transverse airflow greater than 500 lfpm. 1. 10 Series: VEE can vary +0.25 V / −0.5 V. 100 Series: VEE can vary +0.8 V / −0.5 V. Q Zo = 50 W D Driver Receiver Device Device Q Zo = 50 W D 50 W 50 W VTT VTT = VCC − 3.0 V
Figure 2. Typical Termination for Output Driver and Device Evaluation (See Application Note AND8020/D − Termination of ECL Logic Devices) www.onsemi.com 4
