Datasheet FDV301N (Fairchild) - 2
ПроизводительFairchild
ОписаниеDigital FET, N-Channel
Страниц / Страница5 / 2 — Inverter Electrical Characteristics. Symbol. Parameter. Conditions. Min. …
Формат / Размер файлаPDF / 243 Кб
Inverter Electrical Characteristics. Symbol. Parameter. Conditions. Min. Typ. Max. Units. Electrical Characteristics. OFF CHARACTERISTICS
Inverter Electrical Characteristics Symbol Parameter Conditions Min Typ Max Units Electrical Characteristics OFF CHARACTERISTICS
65 предложений от 35 поставщиков
Транзисторы полевые.Тип: MOSFETТип проводимости: NМаксимальное напряжение сток-исток, В: 20Максимальный ток стока (при Ta=25C), А: 1,25Минимальное сопротивление открытого канала, мОм: 300Емкость, пФ:...
Microfind
FDV301N
Fairchild
0.90 ₽
Элевика
FDV301N (Elecsuper)
2.10 ₽
FDV301N
FDV301N
Fairchild
(T = 25°C unless otherwise noted) A
I Zero Input Voltage Output Current V = 20 V, V = 0 V 1 µA O (off) CC I V Input Voltage V = 5 V, I = 10 µA 0.5 V I (off) CC O V V = 0.3 V, I = 0.005 A 1 V I (on) O O R Output to Ground Resistance V = 2.7 V, I = 0.2 A 4 5 Ω O (on) I O
(T = 25 OC unless otherwise noted ) A
Symbol Parameter Conditions Min Typ Max Units OFF CHARACTERISTICS
BV Drain-Source Breakdown Voltage V = 0 V, I = 250 µA 25 V DSS GS D ∆BV /∆T Breakdown Voltage Temp. Coefficient I = 250 µA, Referenced to 25 o C 25 mV / oC DSS J D I Zero Gate Voltage Drain Current V = 20 V, V = 0 V 1 µA DSS DS GS T = 55°C 10 µA J I Gate - Body Leakage Current V = 8 V, V = 0 V 100 nA GSS GS DS
ON CHARACTERISTICS
(Note) ∆V /∆T Gate Threshold Voltage Temp. Coefficient I = 250 µA, Referenced to 25 o C -2.1 mV / oC GS(th) J D V Gate Threshold Voltage V = V , I = 250 µA 0.70 0.85 1.06 V GS(th) DS GS D R Static Drain-Source On-Resistance V = 2.7 V, I = 0.2 A 3.8 5 Ω DS(ON) GS D T =125°C 6.3 9
J
V = 4.5 V, I = 0.4 A 3.1 4 GS D I On-State Drain Current V = 2.7 V, V = 5 V 0.2 A D(ON) GS DS g Forward Transconductance V = 5 V, I = 0.4 A 0.2 S FS DS D
DYNAMIC CHARACTERISTICS
C Input Capacitance V = 10 V, V = 0 V, 9.5 pF iss DS GS f = 1.0 MHz C Output Capacitance 6 pF oss C Reverse Transfer Capacitance 1.3 pF rss
SWITCHING CHARACTERISTICS
(Note) t Turn - On Delay Time V = 6 V, I = 0.5 A, 3.2 8 ns D(on) DD D V = 4.5 V, R = 50 Ω t Turn - On Rise Time GS GEN 6 15 ns r t Turn - Off Delay Time 3.5 8 ns D(off) t Turn - Off Fall Time 3.5 8 ns f Q Total Gate Charge V = 5 V, I = 0.2 A, 0.49 0.7 nC g DS D V = 4.5 V GS Q Gate-Source Charge 0.22 nC gs Q Gate-Drain Charge 0.07 nC gd
DRAIN-SOURCE DIODE CHARACTERISTICS AND MAXIMUM RATINGS
I Maximum Continuous Drain-Source Diode Forward Current 0.29 A S V Drain-Source Diode Forward Voltage V = 0 V, I = 0.29 A (Note) 0.8 1.2 V SD GS S Note: Pulse Test: Pulse Width < 300µs, Duty Cycle < 2.0%. FDV301N Rev.F1
