Datasheet IRF9130 (Intersil) - 3
ПроизводительIntersil
Описание-12A, -100V, 0.30 Ohm, P-Channel Power MOSFET
Страниц / Страница7 / 3 — IRF9130. Source to Drain Diode Specifications. PARAMETER. SYMBOL. TEST …
Формат / Размер файлаPDF / 67 Кб
IRF9130. Source to Drain Diode Specifications. PARAMETER. SYMBOL. TEST CONDITIONS. MIN. TYP. MAX. UNITS. Typical Performance Curves. 1.2
IRF9130 Source to Drain Diode Specifications PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX UNITS Typical Performance Curves 1.2
17 предложений от 17 поставщиков
Non-Compliant Through Hole 12 g 11 mm No SVHC -4 V Through Hole
IRF9130CECCEB
International Rectifier
349 ₽
IRF9130
IRF9130SMD05
TT Electronics
IRF9130
Infineon
Continuous Source to Drain Current ISD Modified MOSFET Symbol - - -12 A Showing the Integral Re-
D
Pulse Source to Drain Current ISDM - - -48 A verse P-N Junction Diode (Note 3)
G S
Source to Drain Diode Voltage (Note 2) VSD TC = 25oC, ISD = -12A, VGS = 0V (Figure 13) - - -1.5 V Reverse Recovery Time trr TJ =150oC, ISD = -12A, dISD/dt = 100A/µs - 300 - ns Reverse Recovery Charge QRR TJ = 150oC, ISD = -12A, dISD/dt = 100A/µs - 1.8 - µC NOTES: 2. Pulse test: pulse width ≤ 300µs, duty cycle ≤ 2%. 3. Repetitive rating: pulse width limited by maximum junction temperature. See Transient Thermal Impedance curve (Figure 3). 4. VDD = 25V, starting TJ = 25oC, L = 5.2mH, RG = 25Ω, peak IAS = 12A. See Figures 15, 16.
Unless Otherwise Specified
1.2 -12.0 1.0 -9.6 TIPLIER 0.8 -7.2 TION MUL 0.6 A -4.8 0.4 , DRAIN CURRENT (A) I D -2.4 WER DISSIP 0.2 PO 0 0 0 25 50 75 100 125 150 25 50 75 100 125 150 TA, CASE TEMPERATURE (oC) TC, CASE TEMPERATURE (oC) FIGURE 1. NORMALIZED POWER DISSIPATION vs CASE FIGURE 2. MAXIMUM CONTINUOUS DRAIN CURRENT vs TEMPERATURE CASE TEMPERATURE 1 C/W) 0.5 o 0.2 ANCE ( P 0.1 DM 0.1 0.05 0.02 0.01 t1 , NORMALIZED TRANSIENT t2
θ
JC SINGLE PULSE NOTES: Z THERMAL IMPED DUTY FACTOR: D = t1/t2 PEAK TJ = PDM x Z
θ
JC x R
θ
JC + TC 0.01 10-5 10-4 10-3 10-2 10-1 1 10 t1, RECTANGULAR PULSE DURATION (s) FIGURE 3. NORMALIZED MAXIMUM TRANSIENT THERMAL IMPEDANCE
5-10
