Datasheet IRL540 (Vishay) - 2
ПроизводительVishay
ОписаниеPower MOSFET
Страниц / Страница9 / 2 — IRL540. THERMAL RESISTANCE RATINGS PARAMETER SYMBOL. TYP. MAX. UNIT. …
Формат / Размер файлаPDF / 259 Кб
IRL540. THERMAL RESISTANCE RATINGS PARAMETER SYMBOL. TYP. MAX. UNIT. SPECIFICATIONS. PARAMETER SYMBOL. TEST. CONDITIONS. MIN. Static. Dynamic
IRL540 THERMAL RESISTANCE RATINGS PARAMETER SYMBOL TYP MAX UNIT SPECIFICATIONS PARAMETER SYMBOL TEST CONDITIONS MIN Static Dynamic
16 предложений от 7 поставщиков
, MOSFET N-CH 100V 28A TO-220AB
IRL540PBF-BE3
от 88 ₽
IRL540PBF-BE3
98 ₽
IRL540PBF-BE3
от 229 ₽
Hi-Tech Circuit Group
IRL540PBF-BE3
IRL540
www.vishay.com Vishay Siliconix
THERMAL RESISTANCE RATINGS PARAMETER SYMBOL TYP. MAX. UNIT
Maximum junction-to-ambient RthJA - 62 Case-to-sink, flat, greased surface RthCS 0.50 - °C/W Maximum junction-to-case (drain) RthJC - 1.0
SPECIFICATIONS
(TJ = 25 °C, unless otherwise noted)
PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. MAX. UNIT Static
Drain-source breakdown voltage VDS VGS = 0 V, ID = 250 μA 100 - - V VDS temperature coefficient ΔVDS/TJ Reference to 25 °C, ID = 1 mA - 0.12 - V/°C Gate-source threshold voltage VGS(th) VDS = VGS, ID = 250 μA 1.0 - 2.0 V Gate-source leakage IGSS VGS = ± 10 V - - ± 100 nA VDS = 100 V, VGS = 0 V - - 25 Zero gate voltage drain current IDSS μA VDS = 80 V, VGS = 0 V, TJ = 150 °C - - 250 VGS = 5.0 V ID = 17 Ab - - 0.077 Drain-source on-state resistance RDS(on) Ω VGS = 4.0 V ID = 14 Ab - - 0.11 Forward transconductance gfs VDS = 50 V, ID = 17 A 12 - - S
Dynamic
Input capacitance Ciss - 2200 - VGS = 0 V, Output capacitance Coss VDS = 25 V, - 560 - pF f = 1.0 MHz, see fig. 5 Reverse transfer capacitance Crss - 140 - Total gate charge Qg - - 64 I Gate-source charge Qgs V D = 28 A, VDS = 80 V, GS = 5.0 V - - 9.4 nC see fig. 6 and 13b Gate-drain charge Qgd - - 27 Turn-on delay time td(on) - 8.5 - Rise time tr V - 170 - DD = 50 V, ID = 28 A, ns Rg = 9.0 Turn-off delay time t Ω, RD = 1.7 Ω, see fig. 10b d(off) - 35 - Fall time tf - 80 - Between lead, D Internal drain inductance LD - 4.5 - 6 mm (0.25") from package and center of nH G Internal source inductance L die contact S - 7.5 - S
Drain-Source Body Diode Characteristics
Continuous source-drain diode current I MOSFET symbol D S - - 28 showing the A integral reverse G Pulsed diode forward current a ISM p - n junction diode S - - 110 Body diode voltage VSD TJ = 25 °C, IS = 28 A, VGS = 0 Vb - - 2.5 V Body diode reverse recovery time trr - 200 260 ns TJ = 25 °C, IF = 28 A, dI/dt = 100 A/μsb Body diode reverse recovery charge Qrr - 1.7 2.90 μC Forward turn-on time ton Intrinsic turn-on time is negligible (turn-on is dominated by LS and LD)
Notes
a. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11) b. Pulse width ≤ 300 μs; duty cycle ≤ 2 % S21-1046-Rev. C, 25-Oct-2021
2
Document Number: 91300 For technical questions, contact: hvm@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
