Datasheet MCR1101-5-3, MCR1101-20-3, MCR1101-50-3 (Aceinna) - 2
ПроизводительAceinna
ОписаниеHigh Accuracy Current Sensor IC with 1.5MHz 3dB Bandwidth and Isolation ±5A, ±20A, ±50A, 3.3V, Ratiometric
Страниц / Страница13 / 2 — ORDERING PART NUMBER. Note: Evaluation boards are available for each …
ORDERING PART NUMBER. Note: Evaluation boards are available for each product version (order EVB-MCx1101-xx-x). Ordering
ORDERING PART NUMBER Note: Evaluation boards are available for each product version (order EVB-MCx1101-xx-x) Ordering
19 предложений от 5 поставщиков
50A, 3.3V, RATIOMETRIC, 1.5MHZ B
MCR1101-50-3
Aceinna
от 703 ₽
Эиком
MCR1101-50-3
Aceinna
от 717 ₽
MCR1101-50-3
68 754 ₽
MCR1101-50-3
229 179 ₽
ORDERING PART NUMBER Note: Evaluation boards are available for each product version (order EVB-MCx1101-xx-x) Ordering Part Marking Current Gain VCC Dielectric Package Qty per PART NUMBER
(See Page 12)
Range (typical) Strength Reel
MCR1101-5-3 MCR11053 ±5 Amp Ratiometric 3.3V 4800V 16 Lead SOIC 1000 pcs MCR1101-20-3 MCR11203 ±20 Amp Ratiometric 3.3V 4800V 16 Lead SOIC 1000 pcs MCR1101-50-3 MCR11503 ±50 Amp Ratiometric 3.3V 4800V 16 Lead SOIC 1000 pcs
PIN DESCRIPTION Pin # Name Description 16L SOIC
1,2,3,4 IP+ Input of Primary Current Path for Sensing, Fused internally 5,6,7,8 IP- Output of Primary Current Path for Sensing, Fused internally 9 FAULTB Overcurrent FAULTB open drain output. Active low. 10 VCC System Power Supply 11 GND Recommended to connect to ground 12 Vout Analog Output Signal linearly proportional to Primary Path Current 13 Vcap Connect 10nF capacitance to ground Used during initial factory calibration. This pin should be 14 GND connected to ground or left floating during normal operation. Pin 1 15 GND Connect to ground Input pin. Voltage on this pin defines the overcurrent detection 16-pin SOIC 16 VOC OCD threshold level. Briefly driving this pin to VCC resets and re- arms OCD circuit.
BLOCK DIAGRAM
Figure 2 - Block diagram for ratiometric gain products Phone: 978.965.3200 Fax: 978.965.3201 E-mail: info@aceinna.com www.aceinna.com Document: 6020-1103-01 Rev C Page 2 of 13
