Datasheet MAX6126 (Analog Devices) - 10
ОписаниеUltra-High-Precision, Ultra-Low-Noise, Series Voltage Reference
Страниц / Страница28 / 10 — Electrical Characteristics—MAX6126_50 (VOUT = 5.000V). PARAMETER. SYMBOL. …
Формат / Размер файлаPDF / 4.0 Мб
Electrical Characteristics—MAX6126_50 (VOUT = 5.000V). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. OUTPUT
Electrical Characteristics—MAX6126_50 (VOUT = 5.000V) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS OUTPUT
54 предложений от 24 поставщиков
Источник опорного напряжения - фиксированный, 2.5В, ± 3млн-1/°C, µMax-8
MAX6126A25+T
Maxim
195 ₽
MAX6126A25+T
763 ₽
Эиком
MAX6126A25+
от 1 235 ₽
MAX6126A25+
Maxim
от 1 720 ₽
MAX6126 Ultra-High-Precision, Ultra-Low-Noise, Series Voltage Reference
(VIN = 5.5V, CLOAD = 0.1μF, IOUT = 0, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.)
Output Voltage VOUT TA = +25°C 5.000 V A grade SO -0.02 +0.02 B grade SO -0.06 +0.06 Output Voltage Accuracy TA = +25°C % A grade µMAX -0.06 +0.06 B grade µMAX -0.1 +0.1 A grade SO 0.5 3 B grade SO 1 5 TA = -40°C to +85°C A grade µMAX 1 3 Output Voltage Temperature B grade µMAX 2 7 Coefficient (Note 1) TCVOUT ppm/°C A grade SO 1 5 TA = -40°C to B grade SO 2 10 +125°C A grade µMAX 2 5 B grade µMAX 3 12 T Line Regulation ΔVOUT/ A = +25°C 3 40 ΔV 5.2V ≤ VIN ≤ 12.6V µV/V IN TA = -40°C to +125°C 80 Sourcing: 0 ≤ I Load Regulation ΔVOUT/ OUT ≤ 10mA 2.5 50 ΔI µV/mA OUT Sinking: -10mA ≤ IOUT ≤ 0 6.5 50 I Dropout Voltage (Note 3) V OUT = 5mA 0.05 0.2 IN - VOUT ΔVOUT = 0.1% V IOUT = 10mA 0.1 0.4 Short to GND 160 OUT Short-Circuit Current ISC mA Short to IN 20 SO 15 Thermal Hysteresis (Note 2) ΔVOUT/ cycle ppm µMAX 80 SO 20 Long-Term Stability ΔVOUT/ ppm/ time 1000hr at TA = +25°C µMAX 100 1000hr
DYNAMIC CHARACTERISTICS
f = 0.1Hz to 10Hz 2.85 µVP-P Noise Voltage eOUT f = 1kHz, CNR = 0 145 nV/√Hz f = 1kHz, CNR = 0.1µF 95 Capacitive-Load Stability Range CLOAD No sustained oscillations 0.1 to 10 µF www.maximintegrated.com Maxim Integrated │ 10
