Datasheet BC337, BC337-25, BC337-40 (ON Semiconductor) - 2
| Производитель | ON Semiconductor |
| Описание | Amplifier Transistors NPN Silicon |
| Страниц / Страница | 8 / 2 — BC337, BC337−25, BC337−40. ELECTRICAL CHARACTERISTICS. Characteristic. … |
| Версия | 8 |
| Формат / Размер файла | PDF / 187 Кб |
BC337, BC337−25, BC337−40. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. Min. Typ. Max. Unit. OFF CHARACTERISTICS
6 предложений от 6 поставщиков TRANS NPN 45V 0.8A. Bipolar (BJT) Transistor NPN 45V 800mA 210MHz 625mW Through Hole TO-92 (TO-226). Transistors - Bipolar (BJT) -... |
| BC337-25RLRAG ON Semiconductor | по запросу | |
| BC337-25RLRAG
| по запросу | |
BC337, BC337−25, BC337−40 ELECTRICAL CHARACTERISTICS
(TA = 25°C unless otherwise noted)
Characteristic Symbol Min Typ Max Unit OFF CHARACTERISTICS
Collector−Emitter Breakdown Voltage V(BR)CEO 45 − − Vdc (IC = 10 mA, IB = 0) Collector−Emitter Breakdown Voltage V(BR)CES 50 − − Vdc (IC = 100 mA, IE = 0) Emitter−Base Breakdown Voltage V(BR)EBO 5.0 − − Vdc (IE = 10 mA, IC = 0) Collector Cutoff Current ICBO − − 100 nAdc (VCB = 30 V, IE = 0) Collector Cutoff Current ICES − − 100 nAdc (VCE = 45 V, VBE = 0) Emitter Cutoff Current IEBO − − 100 nAdc (VEB = 4.0 V, IC = 0)
ON CHARACTERISTICS
DC Current Gain hFE − (IC = 100 mA, VCE = 1.0 V) BC337 100 − 630 BC337−25 160 − 400 BC337−40 250 − 630 (IC = 300 mA, VCE = 1.0 V) 60 − − Base−Emitter On Voltage VBE(on) − − 1.2 Vdc (IC = 300 mA, VCE = 1.0 V) Collector−Emitter Saturation Voltage VCE(sat) − − 0.7 Vdc (IC = 500 mA, IB = 50 mA)
SMALL−SIGNAL CHARACTERISTICS
Output Capacitance Cob − 15 − pF (VCB = 10 V, IE = 0, f = 1.0 MHz) Current−Gain − Bandwidth Product fT − 210 − MHz (IC = 10 mA, VCE = 5.0 V, f = 100 MHz) Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions. 1.0 0.7 D = 0.5 0.5 0.3 TRANSIENT 0.2 ANCE 0.2 0.1 qJC(t) = (t) qJC 0.1 0.05 qJC = 100°C/W MAX RESIST P(pk) q 0.07 0.02 JA(t) = r(t) qJA SINGLE PULSE q 0.05 JA = 375°C/W MAX t1 D CURVES APPLY FOR THERMAL 0.01 0.03 SINGLE PULSE t POWER 2 PULSE TRAIN SHOWN 0.02 , NORMALIZED EFFECTIVE DUTY CYCLE, D = t1/t2 READ TIME AT t1 r(t) TJ(pk) − TC = P(pk) qJC(t) 0.01 0.001 0.002 0.005 0.01 0.02 0.05 0.1 0.2 0.5 1.0 2.0 5.0 10 20 50 100 t, TIME (SECONDS)
Figure 1. Thermal Response http://onsemi.com 2
