Datasheet ADG333A (Analog Devices) - 5
ОписаниеQuad SPDT Switch
Страниц / Страница13 / 5 — Data Sheet. ADG333A. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter. Min. …
ВерсияB
Формат / Размер файлаPDF / 246 Кб
Data Sheet. ADG333A. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter. Min. Table 4. Truth Table. Logic. Switch A. Switch B. ESD CAUTION
Data Sheet ADG333A ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Min Table 4 Truth Table Logic Switch A Switch B ESD CAUTION
41 предложений от 22 поставщиков
Микросхема Чип аналогового переключателя, ANALOG DEVICES ADG333ABRZ Analog Switch, Quad Channel, SPDT, 4Channels, 45Ω, 3V to 30V, SOIC, 20Pins
ADG333ABRZ
193 ₽
Триема
ADG333ABRZ soic-20 микросхема
405 ₽
Эиком
ADG333ABRZ
от 978 ₽
ADG333ABRZ
TA = 25°C unless otherwise noted. Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a
Table 3.
stress rating only; functional operation of the product at these
Parameter Min
or any other conditions above those indicated in the operational VDD to VSS +44 V section of this specification is not implied. Operation beyond VDD to GND −0.3 V to +30 V the maximum operating conditions for extended periods may VSS to GND +0.3 V to −30 V affect product reliability. Analog, Digital Inputs1 VSS − 2 V to VDD + 2 V or 20 mA, whichever occurs first
Continuous Current, S or D 20 mA
Peak Current, S or D (Pulsed at 40 mA 0 Off On 1 ms, 10% Duty Cycle Max) 1 On Off Operating Temperature Range Industrial (B Version) −40°C to +85°C Storage Temperature Range −65°C to +125°C
ESD CAUTION
Junction Temperature 150°C θJA, Thermal Impedance PDIP Package 103°C/W SOIC Package 74°C/W SSOP Package 130°C/W Lead Temperature, Soldering 10 sec 260°C Vapor Phase (60 sec) 215°C Infrared (15 sec) 220°C 1 Overvoltage at IN, S, or D is clamped by internal diodes. Current should be limited to the maximum ratings given. Rev. B | Page 5 of 13 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION TERMINOLOGY PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS APPLICATIONS INFORMATION ADG333A SUPPLY VOLTAGES POWER SUPPLY SEQUENCING OUTLINE DIMENSIONS ORDERING GUIDE
