Datasheet ADG1519 (Analog Devices) - 10
Описание3.8 Ω On-Resistance, SPDT Switch
Страниц / Страница15 / 10 — ADG1519. TEST CIRCUITS. Figure 20. On Leakage. Figure 18. On Resistance …
Формат / Размер файлаPDF / 673 Кб
ADG1519. TEST CIRCUITS. Figure 20. On Leakage. Figure 18. On Resistance (IDS Is the Drain to Source Current.)
ADG1519 TEST CIRCUITS Figure 20 On Leakage Figure 18 On Resistance (IDS Is the Drain to Source Current.)
23 предложений от 7 поставщиков
Микросхема: 8-LEAD LEAD FRAME CHIP SCALE PAC
ADG1519BCPZ-RL7
от 62 ₽
ADG1519BCPZ-RL7
186 ₽
ADG1519BCPZ-RL7
473 ₽
ADG1519BCPZ-RL7
Data Sheet
ADG1519 TEST CIRCUITS Figure 20. On Leakage Figure 18. On Resistance (IDS Is the Drain to Source Current.) Figure 19. Off Leakage Figure 21. Switching Times, tON and tOFF (VOUT Is the Output Voltage.) Figure 22. Break-Before-Make Time Delay Figure 23. Enable Delay, tON (EN), tOFF (EN) Figure 24. Charge Injection analog.com Rev. 0 | 10 of 15
Document Outline Features Applications General Description Functional Block Diagram Product Highlights Specifications Dual Supply Continuous Current Per Channel, Sx or D Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Terminology IDD ISS VD and VS RON RFLAT ON IS Off ID Off ID and IS On VINL VINH IINL and IINH CS Off CD Off CD and CS On CIN tON EN tOFF EN tTRANSITION TD Charge Injection Off Isolation Crosstalk Bandwidth Insertion Loss THD + N THD AC PSRR Applications Information Power Amplifier Gate Drive Power Supply Rails Power Supply Recommendations Outline Dimensions Ordering Guide Evaluation Boards
