Datasheet ADG798 (Analog Devices) - 4
ОписаниеHigh Temperature, Low Voltage 8-Channel Multiplexer
Страниц / Страница22 / 4 — ADG798. Data Sheet. TSSOP. FLATPACK. Parameter. Symbol Test …
ВерсияA
Формат / Размер файлаPDF / 433 Кб
ADG798. Data Sheet. TSSOP. FLATPACK. Parameter. Symbol Test Conditions/Comments1. Min. Typ2. Max. Typ. Unit
ADG798 Data Sheet TSSOP FLATPACK Parameter Symbol Test Conditions/Comments1 Min Typ2 Max Typ Unit
14 предложений от 10 поставщиков
ADG798HFZ
13 909 ₽
ЧипСити
ADG798HFZ
20 047 ₽
ADG798HFZ
21 093 ₽
Эиком
ADG798HFZ
от 27 707 ₽
ADG798 Data Sheet TSSOP FLATPACK Parameter Symbol Test Conditions/Comments1 Min Typ2 Max Min Typ
2
Max Unit
Drain Capacitance, Off CD (Off) f = 1 MHz 85 85 pF Source/Drain Capacitance, CD (On), f = 1 MHz 96 96 pF On CS (On) POWER REQUIREMENTS VDD = 5.5 V Supply Current IDD Digital inputs = 0 V or 5.5 V 5 35 40 70 μA 1 The ADG798 is qualified for a minimum of 1000 hours of continuous operation at the maximum temperature rating. 2 TA = 25°C, except for the analog switch and power requirements values where TA = 175°C (TSSOP only) or 210°C (FLATPACK only). 3 Guaranteed by design, not subject to production test. Rev. A | Page 4 of 22 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR D ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TRUTH TABLE TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY THEORY OF OPERATION APPLICATIONS INFORMATION POWER SUPPLY SEQUENCING OUTLINE DIMENSIONS ORDERING GUIDE
