Datasheet ADG5243F (Analog Devices) - 6
ОписаниеUser Defined Fault Protection and Detection, 0.8 pC QINJ, Triple SPDT
Страниц / Страница30 / 6 — ADG5243F. Data Sheet. −40°C to. Parameter. +25°C. +85°C. +125°C. Unit. …
ВерсияA
Формат / Размер файлаPDF / 649 Кб
ADG5243F. Data Sheet. −40°C to. Parameter. +25°C. +85°C. +125°C. Unit. Test Conditions/Comments
ADG5243F Data Sheet −40°C to Parameter +25°C +85°C +125°C Unit Test Conditions/Comments
Чип интерфейса, Analog Switch Triple SPDT 20Pin TSSOP T/R
ADG5243FBRUZ-RL7
187 ₽
ADG5243FBRUZ-RL7
ADG5243FBRUZ-RL7
Hi-Tech Circuit Group
ADG5243FBRUZ-RL7
link to page 23 link to page 23 link to page 23 link to page 22 link to page 21 link to page 21 link to page 21 link to page 22 link to page 22 link to page 23 link to page 20 link to page 20 link to page 20 link to page 20 link to page 20
ADG5243F Data Sheet −40°C to −40°C to Parameter +25°C +85°C +125°C Unit Test Conditions/Comments
DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 165 ns typ RL = 1 kΩ, CL = 35 pF 210 230 235 ns max VS = 10 V, see Figure 47 tON (EN) 170 ns typ RL = 1 kΩ, CL = 35 pF 215 240 250 ns max VS = 10 V, see Figure 46 tOFF (EN) 70 ns typ RL = 1 kΩ, CL = 35 pF 85 115 115 ns max VS = 10 V, see Figure 46 Break-Before-Make Time Delay, tD 120 ns typ RL = 1 kΩ, CL = 35 pF 85 ns min VS = 10 V, see Figure 45 Overvoltage Response Time, tRESPONSE 75 ns typ RL = 1 kΩ, CL = 5 pF, see Figure 40 105 105 105 ns max Overvoltage Recovery Time, tRECOVERY 820 ns typ RL = 1 kΩ, CL = 5 pF, see Figure 41 1100 1250 1400 ns max Interrupt Flag Response Time, tDIGRESP 75 ns typ CL = 12 pF, see Figure 42 Interrupt Flag Recovery Time, tDIGREC 65 µs typ CL = 12 pF, see Figure 43 1000 ns typ CL = 12 pF, RPULLUP = 1 kΩ, see Figure 44 Charge Injection, QINJ −1.2 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF, see Figure 48 Off Isolation −74 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 37 Channel-to-Channel Crosstalk −82 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 39 Total Harmonic Distortion Plus Noise, THD + N 0.005 % typ RL = 10 kΩ, VS = 20 V p-p, f = 20 Hz to 20 kHz, see Figure 36 −3 dB Bandwidth 350 MHz typ RL = 50 Ω, CL = 5 pF, see Figure 38 Insertion Loss 10.5 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 38 CS (Off) 4 pF typ VS = 0 V, f = 1 MHz CD (Off) 4 pF typ VS = 0 V, f = 1 MHz CD (On), CS (On) 10 pF typ VS = 0 V, f = 1 MHz POWER REQUIREMENTS VDD = POSFV = +22 V, VSS = NEGFV = −22 V, GND = 0 V, digital inputs = 0 V, 5 V, or VDD Normal Mode IDD 1.3 mA typ IPOSFV 0.15 mA typ IDD + IPOSFV 2 2.1 mA max IGND 0.75 mA typ 1.25 1.4 mA max ISS 0.65 mA typ INEGFV 0.2 mA typ ISS + INEGFV 1.0 1.0 mA max Fault Mode VS = ±55 V, all channels in fault IDD 1.4 mA typ IPOSFV 0.2 mA typ IDD + IPOSFV 2.5 2.8 mA max IGND 0.9 mA typ 1.8 1.9 mA max ISS 0.55 mA typ INEGFV 0.2 mA typ ISS + INEGFV 1.0 1.1 mA max VDD/VSS ±5 V min GND = 0 V ±22 V max GND = 0 V 1 Guaranteed by design; not subject to production test. Rev. A | Page 6 of 30 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR Dx ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY THEORY OF OPERATION SWITCH ARCHITECTURE ESD Performance Trench Isolation USER DEFINED FAULT PROTECTION Power-On Protection Power-Off Protection Digital Input Protection Overvoltage Interrupt Flag APPLICATIONS INFORMATION POWER SUPPLY RAILS POWER SUPPLY SEQUENCING PROTECTION SIGNAL RANGE POWER SUPPLY RECOMMENDATIONS HIGH VOLTAGE SURGE SUPPRESSION INTELLIGENT FAULT DETECTION LARGE VOLTAGE, HIGH FREQUENCY SIGNALS OUTLINE DIMENSIONS ORDERING GUIDE
