Datasheet ADG5243F (Analog Devices) - 7
ОписаниеUser Defined Fault Protection and Detection, 0.8 pC QINJ, Triple SPDT
Страниц / Страница30 / 7 — Data Sheet. ADG5243F. 12 V SINGLE SUPPLY. Table 3. −40°C to. Parameter. …
ВерсияA
Формат / Размер файлаPDF / 649 Кб
Data Sheet. ADG5243F. 12 V SINGLE SUPPLY. Table 3. −40°C to. Parameter. +25°C. +85°C. +125°C. Unit. Test Conditions/Comments
Data Sheet ADG5243F 12 V SINGLE SUPPLY Table 3 −40°C to Parameter +25°C +85°C +125°C Unit Test Conditions/Comments
Чип интерфейса, Analog Switch Triple SPDT 20Pin TSSOP T/R
ADG5243FBRUZ-RL7
625 ₽
727GS
ADG5243FBRUZ-RL7
ADG5243FBRUZ-RL7
Hi-Tech Circuit Group
ADG5243FBRUZ-RL7
link to page 20 link to page 18 link to page 20 link to page 20 link to page 20 link to page 20 link to page 20 link to page 20 link to page 20 link to page 20
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, CDECOUPLING = 0.1 µF, unless otherwise noted.
Table 3. −40°C to −40°C to Parameter +25°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH VDD = 10.8 V, VSS = 0 V, see Figure 35 Analog Signal Range 0 V to VDD V On Resistance, RON 630 Ω typ VS = 0 V to 10 V, IS = −1 mA 690 710 730 Ω max 270 Ω typ VS = 3.5 V to 8.5 V, IS = −1 mA 290 355 410 Ω max On-Resistance Match Between Channels, ∆RON 6 Ω typ VS = 0 V to 10 V, IS = −1 mA 19 19 19 Ω max 1 Ω typ VS = 3.5 V to 8.5 V, IS = −1 mA 5 5 5 Ω max On-Resistance Flatness, RFLAT(ON) 380 Ω typ VS = 0 V to 10 V, IS = −1 mA 440 460 460 Ω max 25 Ω typ VS = 3.5 V to 8.5 V, IS = −1 mA 27 28 28 Ω max Threshold Voltage, VT 0.7 V typ See Figure 27 LEAKAGE CURRENTS VDD = 13.2 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.1 nA typ VS = 1 V/10 V, VD = 10 V/1 V, see Figure 33 ±1 ±2 ±5 nA max Drain Off Leakage, ID (Off) ±0.1 nA typ VS = 1 V/10 V, VD = 10 V/1 V, see Figure 33 ±1 ±2 ±5 nA max Channel On Leakage, ID (On), IS (On) ±0.3 nA typ VS = VD = 1 V/10 V, see Figure 34 ±1.5 ±5 ±10 nA max FAULT Source Leakage Current, IS With Overvoltage ±63 µA typ VDD = 13.2 V, VSS = 0 V, GND = 0 V, VS = ±55 V, see Figure 32 Power Supplies Grounded or Floating ±25 µA typ VDD = 0 V or floating, VSS = 0 V or floating, GND = 0 V, INx = 0 V or floating, VS = ±55 V, see Figure 31 Drain Leakage Current, ID With Overvoltage ±2 nA typ VDD = 13.2 V, VSS = 0 V, GND = 0 V, VS = ±55 V, see Figure 32 ±8 ±15 ±50 nA max Power Supplies Grounded ±5 nA typ VDD = 0 V, VSS = 0 V, GND = 0 V, VS = ±55 V, INx = 0 V, see Figure 31 ±100 ±100 ±100 nA max Power Supplies Floating ±50 ±50 ±50 µA typ VDD = floating, VSS = floating, GND = 0 V,VS = ±55 V, INx = 0 V, see Figure 31 DIGITAL INPUTS/OUTPUTS Input Voltage High, VINH 2.0 V min Low, VINL 0.8 V max Input Current, IINL or IINH ±0.7 µA typ VIN = GND or VDD ±1.1 ±1.2 µA max Digital Input Capacitance, CIN 5.0 pF typ Output Voltage High, VOH 2.0 V min Low, VOL 0.4 V max Rev. A | Page 7 of 30 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR Dx ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY THEORY OF OPERATION SWITCH ARCHITECTURE ESD Performance Trench Isolation USER DEFINED FAULT PROTECTION Power-On Protection Power-Off Protection Digital Input Protection Overvoltage Interrupt Flag APPLICATIONS INFORMATION POWER SUPPLY RAILS POWER SUPPLY SEQUENCING PROTECTION SIGNAL RANGE POWER SUPPLY RECOMMENDATIONS HIGH VOLTAGE SURGE SUPPRESSION INTELLIGENT FAULT DETECTION LARGE VOLTAGE, HIGH FREQUENCY SIGNALS OUTLINE DIMENSIONS ORDERING GUIDE
