Datasheet ADG5404F (Analog Devices) - 5
ОписаниеFault Protection and Detection, 10 Ω RON, 4-Channel Multiplexer
Страниц / Страница30 / 5 — Data Sheet. ADG5404F. ±20 V DUAL SUPPLY. Table 2. −40°C to. Parameter. …
ВерсияC
Формат / Размер файлаPDF / 652 Кб
Data Sheet. ADG5404F. ±20 V DUAL SUPPLY. Table 2. −40°C to. Parameter. +25°C. +85°C. +125°C. Unit. Test Conditions/Comments
Data Sheet ADG5404F ±20 V DUAL SUPPLY Table 2 −40°C to Parameter +25°C +85°C +125°C Unit Test Conditions/Comments
31 предложений от 13 поставщиков
ADG5404FBRUZ-RL7
318 ₽
ADG5404FBRUZ-RL7
836 ₽
ADG5404FBRUZ-RL7
Hi-Tech Circuit Group
ADG5404FBRUZ-RL7
link to page 20 link to page 18 link to page 20 link to page 20 link to page 20 link to page 20 link to page 20 link to page 20 link to page 20 link to page 20
VDD = 20 V ± 10%, VSS = −20 V ± 10%, GND = 0 V, CDECOUPLING = 0.1 µF, unless otherwise noted.
Table 2. −40°C to −40°C to Parameter +25°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH VDD = 18 V, VSS = −18 V, see Figure 31 Analog Signal Range VDD to VSS V On Resistance, RON 10 Ω typ VS = ±15 V, IS = −10 mA 11.5 14.5 16.5 Ω max 9.5 Ω typ VS = ±13.5 V, IS = −10 mA 11 14 16.5 Ω max On-Resistance Match Between Channels, ∆RON 0.65 Ω typ VS = ±15 V, IS = −10 mA 0.9 1.05 1.2 Ω max 0.65 Ω typ VS = ±13.5 V, IS = −10 mA 0.9 1.05 1.2 Ω max On-Resistance Flatness, RFLAT(ON) 1.0 Ω typ VS = ±15 V, IS = −10 mA 1.4 1.5 1.5 Ω max 0.1 Ω typ VS = ±13.5 V, IS = −10 mA 0.4 0.5 0.5 Ω max Threshold Voltage, VT 0.7 V typ See Figure 27 LEAKAGE CURRENTS VDD = 22 V, VSS = −22 V Source Off Leakage, IS (Off) ±0.1 nA typ VS = ±15 V, VD = ±15 V, see Figure 32 ±1.5 ±5.0 ±21 nA max Drain Off Leakage, ID (Off) ±0.3 nA typ VS = ±15 V, VD = ±15 V, see Figure 32 ±1.5 ±16.0 ±66 nA max Channel On Leakage, ID (On), IS (On) ±0.3 nA typ VS = VD = ±15 V, see Figure 33 ±1.5 ±14.0 ±56 nA max FAULT Source Leakage Current, IS With Overvoltage ±85 µA typ VDD = +22 V, VSS = −22 V, GND = 0 V, VS = ±55 V, see Figure 36 Power Supplies Grounded or Floating ±44 µA typ VDD = 0 V or floating, VSS = 0 V or floating, GND = 0 V, INx = 0 V or floating, Ax = 0 V or floating, VS = ±55 V, see Figure 37 Drain Leakage Current, ID DR = floating or >2 V With Overvoltage ±400 nA typ VDD = +22 V, VSS = −22 V, GND = 0 V, VS = ±55 V, see Figure 36 ±1.5 ±1.5 ±1.5 µA max Power Supplies Grounded ±10 nA typ VDD = 0 V, VSS = 0 V, GND = 0 V, VS = ±55 V, EN = 0 V, see Figure 37 ±30 ±50 ±100 nA max Power Supplies Floating ±10 ±10 ±10 µA typ VDD = floating, VSS = floating, GND = 0 V, VS = ±55 V, EN = 0 V, see Figure 37 DIGITAL INPUTS Input Voltage High, VINH 2.0 V min Input Voltage Low, VINL 0.8 V max Input Current, IINL or IINH 0.7 µA typ VIN = VGND or VDD 1.2 µA max Digital Input Capacitance, CIN 6.0 pF typ Output Voltage High, VOH 2.0 V min Output Voltage Low, VOL 0.8 V max Rev. C | Page 5 of 30 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY THEORY OF OPERATION SWITCH ARCHITECTURE ESD Performance Trench Isolation FAULT PROTECTION Power-On Protection Power-Off Protection Digital Input Protection Overvoltage Interrupt Flag APPLICATIONS INFORMATION POWER SUPPLY RAILS POWER SUPPLY SEQUENCING PROTECTION SIGNAL RANGE LOW IMPEDANCE CHANNEL PROTECTION POWER SUPPLY RECOMMENDATIONS HIGH VOLTAGE SURGE SUPPRESSION INTELLIGENT FAULT DETECTION LARGE VOLTAGE, HIGH FREQUENCY SIGNALS OUTLINE DIMENSIONS ORDERING GUIDE
