Datasheet ADG5412F-EP (Analog Devices) - 7
ОписаниеFault Protection and Detection, 10 Ω RON, Quad SPST Switches
Страниц / Страница22 / 7 — Enhanced Product. ADG5412F-EP. 12 V SINGLE SUPPLY. Table 3. −40°C to. …
ВерсияB
Формат / Размер файлаPDF / 603 Кб
Enhanced Product. ADG5412F-EP. 12 V SINGLE SUPPLY. Table 3. −40°C to. −55°C to. Parameter. +25°C. +85°C. +125°C. Unit
Enhanced Product ADG5412F-EP 12 V SINGLE SUPPLY Table 3 −40°C to −55°C to Parameter +25°C +85°C +125°C Unit
Микросхема Мультиплексор, Analog Switch ICs -55V Fault Protected 20V 15V +12V
ADG5412FTRUZ-EP-R7
834 ₽
ADG5412FTRUZ-EP-R7
1 568 ₽
ADG5412FTRUZ-EP-R7
ADG5412FTRUZ-EP-R7
link to page 19 link to page 17 link to page 19 link to page 19 link to page 19 link to page 19 link to page 19 link to page 19 link to page 19 link to page 19
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, CDECOUPLING = 0.1 µF, unless otherwise noted.
Table 3. −40°C to −55°C to Parameter +25°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH VDD = 10.8 V, VSS = 0 V, see Figure 30 Analog Signal Range 0 V to VDD V On Resistance, RON 22 Ω typ VS = 0 V to 10 V, IS = −10 mA 24.5 31 37 Ω max 10 Ω typ VS = 3.5 V to 8.5 V, IS = −10 mA 11.2 14 16.5 Ω max On-Resistance Match Between Channels, ∆RON 0.05 Ω typ VS = 0 V to 10 V, IS = −10 mA 0.5 0.6 0.7 Ω max 0.05 Ω typ VS = 3.5 V to 8.5 V, IS = −10 mA 0.5 0.6 0.7 Ω max On-Resistance Flatness, RFLAT(ON) 12.5 Ω typ VS = 0 V to 10 V, IS = −10 mA 14.5 19 23 Ω max 0.6 Ω typ VS = 3.5 V to 8.5 V, IS = −10 mA 0.9 1.1 1.3 Ω max Threshold Voltage, VT 0.7 V typ See Figure 26 LEAKAGE CURRENTS VDD = 13.2 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.1 nA typ VS = 1 V/10 V, VD = 10 V/1 V, see Figure 31 ±1.5 ±5.0 ±21.0 nA max Drain Off Leakage, ID (Off) ±0.1 nA typ VS = 1 V/10 V, VD = 10 V/1 V, see Figure 31 ±1.5 ±5.0 ±18.0 nA max Channel On Leakage, ID (On), IS (On) ±0.3 nA typ VS = VD = 1 V/10 V, see Figure 32 ±1.5 ±2.0 ±4.5 nA max FAULT Source Leakage Current, IS With Overvoltage ±78 µA typ VDD = 13.2 V, VSS = 0 V, GND = 0 V, VS = ±55 V, see Figure 35 Power Supplies Grounded or Floating ±40 µA typ VDD = 0 V or floating, VSS = 0 V or floating, GND = 0 V, INx = 0 V or floating, VS = ±55 V, see Figure 36 Drain Leakage Current, ID With Overvoltage ±2.0 nA typ VDD = 13.2 V, VSS = 0 V or floating, GND = 0 V, VS = ±55 V, see Figure 35 ±20 ±30 ±65 nA max Power Supplies Grounded ±10 nA typ VDD = 0 V, VSS = 0 V, GND = 0 V, VS = ±55 V, INx = 0 V, see Figure 36 ±30 ±50 ±100 nA max Power Supplies Floating ±10 ±10 ±10 µA typ VDD = floating, VSS = floating, GND = 0 V, VS = ±55 V, INx = 0 V, see Figure 36 DIGITAL INPUTS Input Voltage High, VINH 2.0 V min Input Voltage Low, VINL 0.8 V max Input Current, IINL or IINH 0.7 µA typ VIN = VGND or VDD 1.2 µA max Digital Input Capacitance, CIN 5.0 pF typ Output Voltage High, VOH 2.0 V min Output Voltage Low, VOL 0.8 V max Rev. B | Page 7 of 22 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR Dx ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
