Datasheet ADG5401 (Analog Devices) - 4
ОписаниеHigh Voltage Latch-Up Proof, Single SPST Switch
Страниц / Страница17 / 4 — ADG5401. Data Sheet. ±20 V DUAL SUPPLY. Table 2. Parameter. 25°C. −40°C …
ВерсияA
Формат / Размер файлаPDF / 377 Кб
ADG5401. Data Sheet. ±20 V DUAL SUPPLY. Table 2. Parameter. 25°C. −40°C to +85°C. −40°C to +125°C. Unit. Test Conditions/Comments
ADG5401 Data Sheet ±20 V DUAL SUPPLY Table 2 Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
35 предложений от 14 поставщиков
ADG5401BCPZ-RL7
от 74 ₽
ЧипСити
ADG5401BCPZ-RL7
247 ₽
Эиком
ADG5401BCPZ-RL7
от 535 ₽
ADG5401BCPZ-RL7
от 542 ₽
link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 14 link to page 13 link to page 13 link to page 13 link to page 13
VDD = +20 V ± 10%, VSS = −20 V ± 10%, GND = 0 V, unless otherwise noted.
Table 2. Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VDD to VSS V On Resistance, RON 6 Ω typ VS = ±15 V, IS = −10 mA; see Figure 21 7 9 11 Ω max VDD = +18 V, VSS = −18 V On-Resistance Flatness, RFLAT (ON) 1.2 Ω typ VS = ±15 V, IS = −10 mA 1.7 2.1 2.5 Ω max LEAKAGE CURRENTS VDD = +22 V, VSS = −22 V Source Off Leakage, IS (Off) ±0.1 nA typ VS = ±15 V, VD =  15 V; see Figure 20 ±0.5 ±2 ±20 nA max Drain Off Leakage, ID (Off) ±0.1 nA typ VS = ±15 V, VD =  15 V; see Figure 20 ±0.5 ±2 ±20 nA max Channel On Leakage, ID (On), IS (On) ±0.2 nA typ VS = VD = ±15 V; see Figure 23 ±1 ±8 ±40 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.002 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 6 pF typ DYNAMIC CHARACTERISTICS1 tON 150 ns typ RL = 300 Ω, CL = 35 pF 175 207 219 ns max VS = 10 V; see Figure 26 tOFF 170 ns typ RL = 300 Ω, CL = 35 pF 196 214 223 ns max VS = 10 V; see Figure 26 Charge Injection, QINJ 275 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 27 Off Isolation −50 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 22 Total Harmonic Distortion + Noise 0.01 % typ RL = 1 kΩ, 20 V p-p, f = 20 Hz to (THD + N) 20 kHz; see Figure 24 −3 dB Bandwidth 170 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 25 Insertion Loss −0.5 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 25 CS (Off) 21 pF typ VS = 0 V, f = 1 MHz CD (Off) 23 pF typ VS = 0 V, f = 1 MHz CD (On), CS (On) 75 pF typ VS = 0 V, f = 1 MHz POWER REQUIREMENTS VDD = +22 V, VSS = −22 V IDD 50 µA typ Digital inputs = 0 V or VDD 70 110 µA max ISS 0.001 µA typ Digital inputs = 0 V or VDD 1 µA max VDD/VSS ±9/±22 V min/V max GND = 0 V 1 Guaranteed by design; not subject to production test. Rev. A | Page 4 of 17 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY ±20 V DUAL SUPPLY 12 V SINGLE SUPPLY 36 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY APPLICATIONS INFORMATION TRENCH ISOLATION OUTLINE DIMENSIONS ORDERING GUIDE
