Datasheet ADG5208-EP, ADG5209-EP (Analog Devices) - 6
ОписаниеHigh Voltage Latch-Up Proof, 4-/8-Channel Multiplexers
Страниц / Страница20 / 6 — ADG5208-EP/ADG5209-EP. Enhanced Product. Parameter. 25°C. −40°C to +85°C …
ВерсияADG5208-EP/ADG5209-EP: Enhanced Data Sheet
Формат / Размер файлаPDF / 424 Кб
ADG5208-EP/ADG5209-EP. Enhanced Product. Parameter. 25°C. −40°C to +85°C −55°C to +125°C Unit. Test Conditions/Comments
ADG5208-EP/ADG5209-EP Enhanced Product Parameter 25°C −40°C to +85°C −55°C to +125°C Unit Test Conditions/Comments
26 предложений от 9 поставщиков
Зенер
Россия и страны ТС
ADG5208SRUZ-EP-RL7
от 793 ₽
ADG5208SRUZ-EP-RL7
от 1 767 ₽
Эиком
ADG5208SRUZ-EP-RL7
от 1 891 ₽
Hi-Tech Circuit Group
ADG5208SRUZ-EP-RL7
link to page 17 link to page 17 link to page 17 link to page 17 link to page 18 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 7
DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 200 ns typ RL = 300 Ω, CL = 35 pF 250 295 335 ns max VS = 8 V; see Figure 31 tON (EN) 180 ns typ RL = 300 Ω, CL = 35 pF 225 280 320 ns max VS = 8 V; see Figure 33 tOFF (EN) 165 ns typ RL = 300 Ω, CL = 35 pF 200 225 245 ns max VS = 8 V; see Figure 33 Break-Before-Make Time Delay, tD 95 ns typ RL = 300 Ω, CL = 35 pF 45 ns min VS1 = VS2 = 8 V; see Figure 32 Charge Injection, QINJ 0.2 pC typ VS = 6 V, RS = 0 Ω, CL = 1 nF; see Figure 34 Off Isolation −86 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 29 Channel-to-Channel Crosstalk −80 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 27 −3 dB Bandwidth RL = 50 Ω, CL = 5 pF; see Figure 30 ADG5208-EP 95 MHz typ ADG5209-EP 180 MHz typ Insertion Loss −8.9 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 30 CS (Off) 3.3 pF typ VS = 6 V, f = 1 MHz CD (Off) ADG5208-EP 38 pF typ VS = 6 V, f = 1 MHz ADG5209-EP 19 pF typ VS = 6 V, f = 1 MHz CD (On), CS (On) ADG5208-EP 41 pF typ VS = 6 V, f = 1 MHz ADG5209-EP 24 pF typ VS = 6 V, f = 1 MHz POWER REQUIREMENTS VDD = 13.2 V IDD 40 µA typ Digital inputs = 0 V or VDD 50 75 µA max VDD 9/40 V min/V max GND = 0 V, VSS = 0 V 1 Guaranteed by design; not subject to production test.
36 V SINGLE SUPPLY
VDD = 36 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 4. Parameter 25°C −40°C to +85°C −55°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance, RON 150 Ω typ VS = 0 V to 30 V, IS = −1 mA; see Figure 26 170 215 245 Ω max VDD = 32.4 V, VSS = 0 V On-Resistance Match Between 3.5 Ω typ VS = 0 V to 30 V, IS = −1 mA Channels, ∆RON 8 9 10 Ω max On-Resistance Flatness, RFLAT (ON) 35 Ω typ VS = 0 V to 30 V, IS = −1 mA 55 65 70 Ω max LEAKAGE CURRENTS VDD = 39.6 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.005 nA typ VS = 1 V/30 V, VD = 30 V/1 V; see Figure 28 ±0.1 ±0.2 ±0.4 nA max Rev. C | Page 6 of 20 Document Outline Features Applications General Description Functional Block Diagram Product Highlights Table of Contents Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, Sx, D, or Dx Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Outline Dimensions Ordering Guide
