Datasheet ADG5236 (Analog Devices) - 9
ОписаниеHigh Voltage Latch-Up Proof, Dual SPDT Switches
Страниц / Страница20 / 9 — Data Sheet. ADG5236. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. IN1. …
ВерсияB
Формат / Размер файлаPDF / 398 Кб
Data Sheet. ADG5236. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. IN1. 16 NC. S1A. 15 NC. 14 NC. D1 1. 12 EN. S1B. 13 VDD. TOP VIEW. S1B 2. 11 VDD
Data Sheet ADG5236 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS IN1 16 NC S1A 15 NC 14 NC D1 1 12 EN S1B 13 VDD TOP VIEW S1B 2 11 VDD
27 предложений от 14 поставщиков
Чип интерфейса, Interface IC - analogue switches Analog Devices ADG5236BCPZ-RL7 LFCSP 16 WQ
ADG5236BCPZ-RL7
281 ₽
727GS
ADG5236BCPZ-RL7
от 1 412 ₽
ADG5236BCPZ-RL7
TradeElectronics
ADG5236BCPZ-RL7
link to page 9 link to page 9 link to page 9
Data Sheet ADG5236 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS 1A IN1 1 16 NC N1 S I NC NC S1A 2 15 NC 16 15 14 13 D1 3 14 NC D1 1 12 EN S1B ADG5236 4 13 VDD TOP VIEW S1B 2 ADG5236 11 VDD VSS 5 12 S2B (Not to Scale) V TOP VIEW SS 3 10 S2B GND 6 11 D2 (Not to Scale) GND 4 9 D2 NC 7 10 S2A NC 8 9 IN2 5 6 7 8
003
NC = NO CONNECT NC N2I NC 2A
09769-
S NOTES
004
1. EXPOSED PAD TIED TO SUBSTRATE, VSS. 2. NC = NO CONNECT.
09769- Figure 3. TSSOP Pin Configuration Figure 4. LFCSP Pin Configuration
Table 7. Pin Function Descriptions Pin No. TSSOP LFCSP Mnemonic Description
1 15 IN1 Logic Control Input 1. 2 16 S1A Source Terminal 1A. This pin can be an input or output. 3 1 D1 Drain Terminal 1. This pin can be an input or output. 4 2 S1B Source Terminal 1B. This pin can be an input or output. 5 3 VSS Most Negative Power Supply Potential. 6 4 GND Ground (0 V) Reference. 7, 8, 14 to 16 5, 7, 13, 14 NC No Connect. These pins are open. 9 6 IN2 Logic Control Input 2. 10 8 S2A Source Terminal 2A. This pin can be an input or output. 11 9 D2 Drain Terminal 2. This pin can be an input or output. 12 10 S2B Source Terminal 2B. This pin can be an input or output. 13 11 VDD Most Positive Power Supply Potential. N/A1 12 EN Active High Digital Input. When this pin is low, the device is disabled and all switches are off. When this pin is high, the INx logic inputs determine the on switches. N/A1 EP Exposed Pad Exposed Pad. The exposed pad is connected internally. For increased reliability of the solder joints and maximum thermal capability, it is recommended that the pad be soldered to the substrate, VSS. 1 N/A means not applicable.
TRUTH TABLES FOR SWITCHES Table 8. TSSOP Truth Table INx SxA SxB
0 Off On 1 On Off
Table 9. LFCSP Truth Table EN INx SxA SxB
0 X1 Off Off 1 0 Off On 1 1 On Off 1 X means don’t care. Rev. B | Page 9 of 20 Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, SxA, SxB, or Dx Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Truth Tables for Switches Typical Performance Characteristics Test Circuits Terminology Trench Isolation Applications Information Outline Dimensions Ordering Guide
