Datasheet ADG5408, ADG5409 (Analog Devices) - 7
ОписаниеHigh Voltage Latch-Up Proof, 4-/8-Channel Multiplexers
Страниц / Страница24 / 7 — Data Sheet. ADG5408/ADG5409. Parameter. 25°C. −40°C to +85°C −40°C to …
ВерсияC
Формат / Размер файлаPDF / 413 Кб
Data Sheet. ADG5408/ADG5409. Parameter. 25°C. −40°C to +85°C −40°C to +125°C Unit. Test Conditions/Comments
Data Sheet ADG5408/ADG5409 Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
36 предложений от 15 поставщиков
ADG5409BCPZ-REEL7
от 118 ₽
Зенер
Россия и страны ТС
ADG5409BCPZ-REEL7
от 299 ₽
ADG5409BCPZ-REEL7
575 ₽
ADG5409BCPZ-REEL7
от 935 ₽
link to page 16 link to page 16 link to page 17 link to page 17 link to page 17 link to page 17 link to page 17 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 7
Drain Off Leakage, ID (Off) ±0.15 nA typ VS = 1 V/30 V, VD = 30 V/1 V; see Figure 29 ±0.4 ±4 ±30 nA max Channel On Leakage, ID (On), IS (On) ±0.15 nA typ VS = VD = 1 V/30 V; see Figure 25 ±0.4 ±4 ±30 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.002 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 3 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 187 ns typ RL = 300 Ω, CL = 35 pF 242 257 281 ns max VS = 18 V; see Figure 32 tON (EN) 160 ns typ RL = 300 Ω, CL = 35 pF 195 219 237 ns max VS = 18 V; see Figure 34 tOFF (EN) 147 ns typ RL = 300 Ω, CL = 35 pF 184 184 190 ns max VS = 18 V; see Figure 34 Break-Before-Make Time Delay, tD 53 ns typ RL = 300 Ω, CL = 35 pF 17 ns min VS1 = VS2 = 18 V; see Figure 33 Charge Injection, QINJ 150 pC typ VS = 18 V, RS = 0 Ω, CL = 1 nF; see Figure 35 Off Isolation −60 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 28 Channel-to-Channel Crosstalk −60 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 27 Total Harmonic Distortion + Noise 0.4 % typ RL = 1 kΩ, 18 V p-p, f = 20 Hz to 20 kHz; see Figure 30 −3 dB Bandwidth RL = 50 Ω, CL = 5 pF; see Figure 31 ADG5408 45 MHz typ ADG5409 76 MHz typ Insertion Loss −1 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 31 CS (Off) 18 pF typ VS = 18 V, f = 1 MHz CD (Off) ADG5408 120 pF typ VS = 18 V, f = 1 MHz ADG5409 60 pF typ VS = 18 V, f = 1 MHz CD (On), CS (On) ADG5408 137 pF typ VS = 18 V, f = 1 MHz ADG5409 80 pF typ VS = 18 V, f = 1 MHz POWER REQUIREMENTS VDD = 39.6 V IDD 80 µA typ Digital inputs = 0 V or VDD 100 130 µA max VDD 9/40 V min/V max GND = 0 V, VSS = 0 V 1 Guaranteed by design; not subject to production test. Rev. C | Page 7 of 24 Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, Sx or D Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Trench Isolation Applications Information Outline Dimensions Ordering Guide
