Datasheet ADG5408, ADG5409 (Analog Devices) - 9
ОписаниеHigh Voltage Latch-Up Proof, 4-/8-Channel Multiplexers
Страниц / Страница24 / 9 — Data Sheet. ADG5408/ADG5409. ABSOLUTE MAXIMUM RATINGS. Table 7. …
ВерсияC
Формат / Размер файлаPDF / 413 Кб
Data Sheet. ADG5408/ADG5409. ABSOLUTE MAXIMUM RATINGS. Table 7. Parameter. Rating. ESD CAUTION
Data Sheet ADG5408/ADG5409 ABSOLUTE MAXIMUM RATINGS Table 7 Parameter Rating ESD CAUTION
Чип интерфейса, Analog Multiplexer Single 4: 1 16Pin LFCSP T/R
ADG5409TCPZ-EP-RL7
728 ₽
ADG5409TCPZ-EP-RL7
774 ₽
ADG5409TCPZ-EP-RL7
961 ₽
Hi-Tech Circuit Group
ADG5409TCPZ-EP-RL7
link to page 8 link to page 9 link to page 9 link to page 9
TA = 25°C, unless otherwise noted.
Table 7.
Stresses above those listed under Absolute Maximum Ratings
Parameter Rating
may cause permanent damage to the device. This is a stress V rating only; functional operation of the device at these or any DD to VSS 48 V other conditions above those indicated in the operational VDD to GND −0.3 V to +48 V section of this specification is not implied. Exposure to absolute VSS to GND +0.3 V to −48 V maximum rating conditions for extended periods may affect Analog Inputs1 VSS − 0.3 V to VDD + 0.3 V or 30 mA, whichever occurs first device reliability. Digital Inputs1 VSS − 0.3 V to VDD + 0.3 V or Only one absolute maximum rating can be applied at any 30 mA, whichever occurs first one time. Peak Current, Sx or D Pins
ESD CAUTION
ADG5408 435 mA (pulsed at 1 ms, 10% duty cycle maximum) ADG5409 300 mA (pulsed at 1 ms, 10% duty cycle maximum) Continuous Current, Sx or D2 Data + 15% Temperature Range Operating −40°C to +125°C Storage −65°C to +150°C Junction Temperature 150°C Thermal Impedance, θJA 16-Lead TSSOP (4-Layer 112.6°C/W Board) 16-Lead LFCSP (4-Layer 30.4°C/W Board) Reflow Soldering Peak As per JEDEC J-STD-020 Temperature, Pb Free 1 Overvoltages at the Ax, EN, Sx, and D pins are clamped by internal diodes. Limit current to the maximum ratings given. 2 See Table 5. Rev. C | Page 9 of 24 Document Outline Features Applications Functional Block Diagrams General Description Product Highlights Revision History Specifications ±15 V Dual Supply ±20 V Dual Supply 12 V Single Supply 36 V Single Supply Continuous Current per Channel, Sx or D Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Trench Isolation Applications Information Outline Dimensions Ordering Guide
