Datasheet ADG1419 (Analog Devices) - 5
Описание2.1 Ω On Resistance, ±15 V/+12 V/±5 V, iCMOS SPDT Switch
Страниц / Страница16 / 5 — Data Sheet. ADG1419. Parameter. 25°C. −40°C to +85°C. −40°C to +125°C. …
ВерсияA
Формат / Размер файлаPDF / 442 Кб
Data Sheet. ADG1419. Parameter. 25°C. −40°C to +85°C. −40°C to +125°C. Unit. Test Conditions/Comments. ±5 V DUAL SUPPLY
Data Sheet ADG1419 Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments ±5 V DUAL SUPPLY
50 предложений от 20 поставщиков
Микросхема Чип аналогового переключателя, ANALOG DEVICES ADG1419BCPZ-REEL7 Analog Switch, Single Channel, SPDT, 1Channels, 2.4Ω, ± 4.5V to ± 16.5V, LFCSP, 8Pins...
ADG1419BCPZ-REEL7
123 ₽
ADG1419BCPZ-REEL7
от 178 ₽
ADG1419BCPZ-REEL7
699 ₽
ЗУМ-СМД
ADG1419BCPZ-REEL7
link to page 13 link to page 13 link to page 13 link to page 12 link to page 12 link to page 12 link to page 12
Channel-to-Channel Crosstalk −60 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 30 −3 dB Bandwidth 95 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 31 Insertion Loss 0.3 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 31 CS (Off ) 32 pF typ f = 1 MHz; VS = 6 V CD (Off ) 72 pF typ f = 1 MHz; VS = 6 V CD, CS (On) 123 pF typ f = 1 MHz; VS = 6 V POWER REQUIREMENTS VDD = 13.2 V IDD 0.001 μA typ Digital inputs = 0 V or VDD 1.0 μA max IDD, 8-Lead MSOP 58 μA typ Digital inputs = 5 V 95 μA max IDD, 8-Lead LFCSP 120 μA typ Digital inputs = 5 V 190 μA max VDD 5/16.5 V min/max Ground = 0 V, VSS = 0 V 1 Guaranteed by design, not subject to production test.
±5 V DUAL SUPPLY
VDD = +5 V ± 10%, VSS = −5 V ± 10%, GND = 0 V, unless otherwise noted.
Table 3. Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VDD to VSS V On Resistance, RON 4.5 Ω typ VS = ±4.5V, IS = −10 mA; see Figure 22 5.2 6.2 7 Ω max VDD = +4.5 V, VSS = −4.5 V On-Resistance Match Between 0.1 Ω typ VS = ±4.5V, IS = −10 mA Channels, ∆RON 0.3 0.35 0.4 Ω max On-Resistance Flatness, RFLAT (ON) 1.3 Ω typ VS = ±4.5 V, IS = −10 mA 1.6 1.85 2 Ω max LEAKAGE CURRENTS VDD = +5.5 V, VSS = −5.5 V Source Off Leakage, IS (Off ) ±0.1 nA typ VS = ±4.5 V, VD = ∓4.5 V; see Figure 23 ±0.5 ±2 ±75 nA max Drain Off Leakage, ID (Off ) ±0.1 nA typ VS = ±4.5 V, VD = ∓4.5 V; see Figure 23 ±0.6 ±3 ±100 nA max Channel On Leakage, ID, IS (On) ±0.1 nA typ VS = VD = ±4.5 V; see Figure 24 ±1 ±3 ±100 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.001 μA typ VIN = VGND or VDD ±0.1 μA max Digital Input Capacitance, CIN 4 pF typ Rev. A | Page 5 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY +12 V SINGLE SUPPLY ±5 V DUAL SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
