Datasheet ADG1606, ADG1607 (Analog Devices) - 9
Описание4.5 Ω RON, 16-Channel, Differential 8-Channel, ±5 V,+12 V,+5 V, and +3.3 V Multiplexers
Страниц / Страница22 / 9 — Data Sheet. ADG1606/ADG1607. PIN CONFIGURATIONS AND FUNCTION …
ВерсияA
Формат / Размер файлаPDF / 518 Кб
Data Sheet. ADG1606/ADG1607. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. VSS. S16. S16 1. 24 S8. S15 2. 23 S7. S15. ADG1606. S14 3. 22 S6. S14
Data Sheet ADG1606/ADG1607 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS VSS S16 S16 1 24 S8 S15 2 23 S7 S15 ADG1606 S14 3 22 S6 S14
55 предложений от 24 поставщиков
ADG1606BRUZ
от 156 ₽
Зенер
Россия и страны ТС
ADG1606BRUZ-REEL7
от 434 ₽
ADG1606BRUZ
S-Line
ADG1606BRUZ
Data Sheet ADG1606/ADG1607 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS V 1 28 DD D DD SS NC V NC D NC NC NC V NC 2 27 VSS 32 31 30 29 28 27 26 25 NC 3 26 S8 S16 4 25 S7 S16 1 24 S8 S15 2 23 S7 S15 5 24 S6 ADG1606 S14 3 22 S6 S14 6 TOP VIEW 23 S5 ADG1606 S13 4 21 S5 (Not to Scale) TOP VIEW S13 7 22 S4 S12 5 20 S4 (Not to Scale) 6 19 S12 S11 S3 8 21 S3 S10 7 18 S2 S11 9 20 S2 S9 8 17 S1 S10 10 19 S1 9 1 S9 11 18 EN 10 1 12 13 14 15 16 GND 12 17 A0 ND A3 A2 NC NC A1 A0 EN G NC 13 16 A1 A3 14 15 A2 NOTES
003
1. NC = NO CONNECT.
004
NC = NO CONNECT 2. EXPOSED PAD TIED TO SUBSTRATE, V
08489-
SS.
08489- Figure 3. ADG1606 TSSOP Pin Configuration Figure 4. ADG1606 LFCSP Pin Configuration
Table 9. ADG1606 P in Function Descriptions Pin No. TSSOP LFCSP Mnemonic Description
1 31 VDD Most Positive Power Supply Potential. 2, 3, 13 12, 13, 26, NC No Connect. 27, 28, 30, 32 4 1 S16 Source Terminal 16. This pin can be an input or an output. 5 2 S15 Source Terminal 15. This pin can be an input or an output. 6 3 S14 Source Terminal 14. This pin can be an input or an output. 7 4 S13 Source Terminal 13. This pin can be an input or an output. 8 5 S12 Source Terminal 12. This pin can be an input or an output. 9 6 S11 Source Terminal 11. This pin can be an input or an output. 10 7 S10 Source Terminal 10. This pin can be an input or an output. 11 8 S9 Source Terminal 9. This pin can be an input or an output. 12 9 GND Ground (0 V) Reference. 14 10 A3 Logic Control Input. 15 11 A2 Logic Control Input. 16 14 A1 Logic Control Input. 17 15 A0 Logic Control Input. 18 16 EN Active High Digital Input. When this pin is low, the device is disabled and all switches are turned off. When this pin is high, the Ax logic inputs determine which switch is turned on. 19 17 S1 Source Terminal 1. This pin can be an input or an output. 20 18 S2 Source Terminal 2. This pin can be an input or an output. 21 19 S3 Source Terminal 3. This pin can be an input or an output. 22 20 S4 Source Terminal 4. This pin can be an input or an output. 23 21 S5 Source Terminal 5. This pin can be an input or an output. 24 22 S6 Source Terminal 6. This pin can be an input or an output. 25 23 S7 Source Terminal 7. This pin can be an input or an output. 26 24 S8 Source Terminal 8. This pin can be an input or an output. 27 25 VSS Most Negative Power Supply Potential. In single-supply applications, this pin can be connected to ground. 28 29 D Drain Terminal. This pin can be an input or an output. EPAD Exposed Pad The exposed pad is connected internally. For increased reliability of the solder joints and maximum thermal capability, it is recommended that the pad be soldered to the substrate, VSS. Rev. A | Page 9 of 22 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
