Datasheet ADG1604 (Analog Devices) - 3
Описание1 Ω Typical On Resistance, ±5 V, +12 V, +5 V, and +3.3 V, 4:1 Multiplexer
Страниц / Страница20 / 3 — Data Sheet. ADG1604. SPECIFICATIONS ±5 V DUAL SUPPLY. Table 1. −40°C to …
ВерсияB
Формат / Размер файлаPDF / 461 Кб
Data Sheet. ADG1604. SPECIFICATIONS ±5 V DUAL SUPPLY. Table 1. −40°C to −40°C to. Parameter. 25°C. +85°C. +125°C. Unit
Data Sheet ADG1604 SPECIFICATIONS ±5 V DUAL SUPPLY Table 1 −40°C to −40°C to Parameter 25°C +85°C +125°C Unit
50 предложений от 20 поставщиков
ADG1604BRUZ-REEL7
от 105 ₽
ЧипСити
ADG1604BRUZ-REEL7
203 ₽
ADG1604BRUZ-REEL7
596 ₽
ADG1604BRUZ-REEL7
link to page 13 link to page 13 link to page 13 link to page 13 link to page 14 link to page 15 link to page 15 link to page 14 link to page 15 link to page 13 link to page 13 link to page 14 link to page 13
VDD = +5 V ± 10%, VSS = −5 V ± 10%, GND = 0 V, unless otherwise noted.
Table 1. −40°C to −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VDD to VSS V On Resistance (RON) 1 Ω typ VS = ±4.5 V, IS = −10 mA; see Figure 22 1.2 1.4 1.6 Ω max VDD = ±4.5 V, VSS = ±4.5 V On Resistance Match Between Channels (∆RON) 0.04 Ω typ VS = ±4.5 V, IS = −10 mA 0.08 0.09 0.1 Ω max On Resistance Flatness (RFLAT(ON)) 0.2 Ω typ VS = ±4.5 V, IS = −10 mA 0.25 0.29 0.34 Ω max LEAKAGE CURRENTS VDD = +5.5 V, VSS = −5.5 V Source Off Leakage, IS (Off) ±0.1 nA typ VS = ±4.5 V, VD = ∓4.5 V; see Figure 23 ±0.2 ±1 ±8 nA max Drain Off Leakage, ID (Off) ±0.1 nA typ VS = ±4.5V, VD = ∓4.5 V; see Figure 23 ±0.2 ±2 ±16 nA max Channel On Leakage, ID, IS (On) ±0.2 nA typ VS = VD = ±4.5 V; see Figure 24 ±0.4 ±2 ±16 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.005 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 8 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 150 ns typ RL = 300 Ω, CL = 35 pF 278 336 376 ns max VS = 2.5 V; see Figure 29 tON (EN) 116 ns typ RL = 300 Ω, CL = 35 pF 146 166 177 ns max VS = 2.5 V; see Figure 31 tOFF (EN) 186 ns typ RL = 300 Ω, CL = 35 pF 234 277 310 ns max VS = 2.5 V; see Figure 31 Break-Before-Make Time Delay, tD 50 ns typ RL = 300 Ω, CL = 35 pF 28.5 ns min VS1 = VS2 = 2.5 V; see Figure 30 Charge Injection 140 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 32 Off Isolation 70 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 25 Channel-to-Channel Crosstalk 70 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 27 Total Harmonic Distortion + Noise (THD + N) 0.007 % typ RL = 110 Ω, 5 V p-p, f = 20 Hz to 20 kHz; see Figure 28 −3 dB Bandwidth 15 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 26 CS (Off) 63 pF typ VS = 0 V, f = 1 MHz CD (Off) 270 pF typ VS = 0 V, f = 1 MHz CD, CS (On) 360 pF typ VS = 0 V, f = 1 MHz POWER REQUIREMENTS VDD = +5.5 V, VSS = −5.5 V IDD 0.001 µA typ Digital inputs = 0 V or VDD 1.0 µA max VDD/VSS ±3.3/±8 V min/max 1 Guaranteed by design, not subject to production test. Rev. B | Page 3 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
