Datasheet ADG1404 (Analog Devices) - 5
Описание1.5 Ω On Resistance, ±15 V/12 V/±5 V, 4:1, iCMOS Multiplexer
Страниц / Страница16 / 5 — Data Sheet. ADG1404. 5 V DUAL SUPPLY. Table 3. Parameter. 25°C. −40°C to …
ВерсияB
Формат / Размер файлаPDF / 469 Кб
Data Sheet. ADG1404. 5 V DUAL SUPPLY. Table 3. Parameter. 25°C. −40°C to +85°C. −40°C to +125°C. Unit. Test Conditions/Comments
Data Sheet ADG1404 5 V DUAL SUPPLY Table 3 Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
35 предложений от 16 поставщиков
ADG1404YCPZ-REEL
от 132 ₽
ADG1404YCPZ-REEL7
217 ₽
ЧипСити
ADG1404YCPZ-REEL7
217 ₽
ADG1404YCPZ-REEL
706 ₽
link to page 13 link to page 13 link to page 13 link to page 13 link to page 14 link to page 15 link to page 15 link to page 14 link to page 15 link to page 13 link to page 13 link to page 13 link to page 13 link to page 14
VDD = 5 V ± 10%, VSS = −5 V ± 10%, GND = 0 V, unless otherwise noted.
Table 3. Parameter 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VDD to VSS V On Resistance (RON) 3.3 Ω typ VS = ±4.5 V, IS = −10 mA; see Figure 22 4 4.9 5.4 Ω max VDD = +4.5 V, VSS = −4.5 V On-Resistance Match 0.13 Ω typ VS = ±4.5 V, IS = −10 mA Between Channels (∆RON) 0.22 0.23 0.25 Ω max On-Resistance Flatness (RFLAT(ON)) 0.9 Ω typ VS = ±4.5 V, IS = −10 mA 1.1 1.24 1.31 Ω max LEAKAGE CURRENTS VDD = +5.5 V, VSS = −5.5 V Source Off Leakage, IS (Off) ±0.02 nA typ VS = ±4.5 V, VD = ∓4.5 V; see Figure 23 ±0.2 ±1 ±12.5 nA max Drain Off Leakage, ID (Off) ±0.02 nA typ VS = ±4.5 V, VD = ∓4.5 V; see Figure 23 ±0.25 ±1.2 ±15 nA max Channel On Leakage, ID, IS (On) ±0.05 nA typ VS = VD = ±4.5 V; see Figure 24 ±0.25 ±1.5 ±20 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.001 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 3 5 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 340 ns typ RL = 300 Ω, CL = 35 pF 470 560 615 ns max VS = 3 V; Figure 29 tON (EN) 260 ns typ RL = 300 Ω, CL = 35 pF 355 430 480 ns max VS = 3 V; Figure 31 tOFF (EN) 220 ns typ RL = 300 Ω, CL = 35 pF 315 365 400 ns max VS = 3 V; Figure 31 Break-Before-Make Time Delay, tBBM 100 ns typ RL = 300 Ω, CL = 35 pF 50 ns min VS1 = VS2 = 3 V; see Figure 30 Charge Injection 30 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 32 Off Isolation 80 dB typ RL = 50 Ω, CL = 5 pF, f = 100 kHz; see Figure 25 Channel-to-Channel Crosstalk 82 dB typ RL = 50 Ω, CL = 5 pF, f = 100 kHz; see Figure 27 −3 dB Bandwidth 40 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 26 Insertion Loss 0.27 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 26 Total Harmonic Distortion + Noise 0.03 % typ RL = 110 Ω, 2.5 V p-p, f = 20 Hz to 20 kHz; see Figure 28 CS (Off) 33 pF typ VS = 0 V, f = 1 MHz CD (Off) 128 pF typ VS = 0 V, f = 1 MHz CD, CS (On) 210 pF typ VS = 0 V, f = 1 MHz POWER REQUIREMENTS VDD = 5.5 V, VSS = −5.5 V IDD 0.001 µA typ Digital inputs = 0 V, 5 V, or VDD 1 µA max ISS 0.001 µA typ Digital inputs = 0 V or VDD 1 µA max VDD/VSS ±4.5/±16.5 V min/max GND = 0 V 1 Guaranteed by design, not subject to production test. Rev. B | Page 5 of 16 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications 15 V Dual Supply 12 V Single Supply 5 V Dual Supply Continuous Current, S or D Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Truth Table Typical Performance Characteristics Terminology Test Circuits Outline Dimensions Ordering Guide
