Datasheet ADG1406, ADG1407 (Analog Devices) - 3
Описание9.5 Ω RON, 16-Channel, Differential 8-Channel, ±15 V/+12 V/±5 V iCMOS Multiplexers
Страниц / Страница20 / 3 — Data Sheet. ADG1406/ADG1407. SPECIFICATIONS ±15 V DUAL SUPPLY. Table 2. …
ВерсияC
Формат / Размер файлаPDF / 511 Кб
Data Sheet. ADG1406/ADG1407. SPECIFICATIONS ±15 V DUAL SUPPLY. Table 2. −40°C to. Parameter +25°C. +85°C. +125°C. Unit. Test
Data Sheet ADG1406/ADG1407 SPECIFICATIONS ±15 V DUAL SUPPLY Table 2 −40°C to Parameter +25°C +85°C +125°C Unit Test
45 предложений от 19 поставщиков
ЧипСити
ADG1407BRUZ-REEL7
533 ₽
Элрус
ADG1407BRUZ-REEL7
от 934 ₽
ADG1407BRUZ-REEL7
969 ₽
Hi-Tech Circuit Group
ADG1407BRUZ-REEL7
link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 19 link to page 19 link to page 19 link to page 19 link to page 19 link to page 19 link to page 4 link to page 4 link to page 4
VDD = +15 V ± 10%, VSS = –15 V ± 10%, GND = 0 V, unless otherwise noted.1
Table 2. −40°C to −40°C to Parameter +25°C +85°C +125°C
1
Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VSS to VDD V On Resistance (RON) 9.5 Ω typ VDD = +13.5 V, VSS = −13.5 V, VS = ±10 V, 11.5 14 16 Ω max IS = −10 mA; see Figure 27 On-Resistance Match Between 0.55 Ω typ VDD = +13.5 V, VSS = −13.5 V , VS = ±10 V, Channels (ΔRON) IS = −10 mA 1 1.5 1.7 Ω max On-Resistance Flatness (RFLAT(ON)) 1.6 Ω typ VDD = +13.5 V, VSS = −13.5 V, VS = ±10 V, IS = −10 mA 1.9 2.15 2.3 Ω max LEAKAGE CURRENTS VDD = +16.5 V, VSS = −16.5 V Source Off Leakage, IS (Off ) ±0.01 nA typ VS = ±10 V, VD = ∓10 V; see Figure 28 ±0.25 ±1 ±4 nA max Drain Off Leakage, ID (Off ) ±0.01 nA typ VS = ±10 V, VD = ∓10 V; see Figure 28 ±0.5 ±3 ±20 nA max Channel On Leakage, ID, IS (On) ±0.05 nA typ VS = VD = ±10 V; see Figure 29 ±0.5 ±3 ±20 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current ±0.002 μA typ VIN = VGND or VDD ±0.1 μA max Digital Input Capacitance, CIN 3 pF typ DYNAMIC CHARACTERISTICS2 Transition Time, tTRANSITION 105 ns typ RL = 100 Ω, CL = 35 pF 160 200 225 ns max VS = 10 V, see Figure 30 Break-Before-Make Time Delay, tBBM 40 ns typ RL = 100 Ω, CL = 35 pF 10 ns min VS1 = VS2 = 10 V; see Figure 31 tON (EN) 83 ns typ RL = 100 Ω, CL = 35 pF 110 140 155 ns max VS = 10 V; see Figure 32 tOFF (EN) 98 ns typ RL = 100 Ω, CL = 35 pF 120 145 165 ns max VS = 10 V; see Figure 32 Charge Injection 10 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 33 Off Isolation −73 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 34 Channel-to-Channel Crosstalk −70 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 35 Total Harmonic Distortion Plus Noise 0.07 % typ RL = 110 Ω, 15 V p-p, f = 20 Hz to 20 kHz; see (THD + N) Figure 37 −3 dB Bandwidth RL = 50 Ω, CL = 5 pF; see Figure 36 ADG1406 60 MHz typ ADG1407 110 MHz typ Insertion Loss 0.6 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 36 CS (Off ) 8 pF typ f = 1 MHz CD (Off ) f = 1 MHz ADG1406 90 pF typ ADG1407 45 pF typ Rev. C | Page 3 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY 12 V SINGLE SUPPLY ±5 V DUAL SUPPLY CONTINUOUS CURRENT PER CHANNEL ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
