Datasheet ADG1406, ADG1407 (Analog Devices) - 4
Описание9.5 Ω RON, 16-Channel, Differential 8-Channel, ±15 V/+12 V/±5 V iCMOS Multiplexers
Страниц / Страница20 / 4 — ADG1406/ADG1407. Data Sheet. −40°C to. Parameter +25°C. +85°C. +125°C. …
ВерсияC
Формат / Размер файлаPDF / 511 Кб
ADG1406/ADG1407. Data Sheet. −40°C to. Parameter +25°C. +85°C. +125°C. Unit. Test. Conditions/Comments. 12 V SINGLE SUPPLY
ADG1406/ADG1407 Data Sheet −40°C to Parameter +25°C +85°C +125°C Unit Test Conditions/Comments 12 V SINGLE SUPPLY
37 предложений от 14 поставщиков
ADG1407BCPZ-REEL7
371 ₽
ADG1407BCPZ-REEL7
1 003 ₽
ADG1407BCPZ-REEL7
1 258 ₽
Hi-Tech Circuit Group
ADG1407BCPZ-REEL7
link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 5 link to page 5
ADG1406/ADG1407 Data Sheet −40°C to −40°C to Parameter +25°C +85°C +125°C
1
CD, CS (On) f = 1 MHz ADG1406 115 pF typ ADG1407 70 pF typ POWER REQUIREMENTS VDD = +16.5 V, VSS = −16.5 V IDD 0.002 μA typ Digital inputs = 0 V or VDD 1 μA max IDD 280 μA typ Digital inputs = 5 V 475 μA max ISS 0.002 μA typ Digital inputs = 0 V, 5 V or VDD 1 μA max VDD/VSS ±4.5/±16.5 V min/max 1 Temperature range for B version is −40°C to +125°C. 2 Guaranteed by design, not subject to production test.
12 V SINGLE SUPPLY
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 3. Parameter +25°C −40°C to +85°C −40°C to +125°C1 Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 to VDD V On Resistance (RON) 18 Ω typ VDD = 10.8 V, VSS = 0 V; VS = 0 V to 10 V, IS = −10 mA; see Figure 27 21.5 26 28.5 Ω max On-Resistance Match Between 0.55 Ω typ VDD = 10.8 V, VSS = 0 V; VS = 0 V to 10 V, Channels (ΔRON) IS = −10 mA 1.2 1.6 1.8 Ω max On-Resistance Flatness (RFLAT(ON)) V 5 Ω typ DD = 10.8 V, VSS = 0 V; VS = 0 V to 10 V, IS = −10 mA 6 6.9 7.3 Ω max LEAKAGE CURRENTS VDD = 10.8 V Source Off Leakage, IS (Off ) ±0.01 nA typ VS = 1 V/10 V, VD = 10 V/1 V; see Figure 28 ±0.25 ±1 ±4 nA max Drain Off Leakage, ID (Off ) ±0.01 nA typ VS = 1 V/10 V, VD = 10 V/1 V; see Figure 28 ±0.5 ±3 ±20 nA max Channel On Leakage, ID, IS (On) ±0.01 nA typ VS = VD = 1 V or 10 V; see Figure 29 ±0.5 ±3 ±20 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current ±0.002 μA typ VIN = VGND or VDD ±0.1 μA max Digital Input Capacitance, CIN 4 pF typ DYNAMIC CHARACTERISTICS2 Transition Time, tTRANSITION 170 ns typ RL = 100 Ω, CL = 35 pF 250 310 350 ns max VS = 8 V; see Figure 29 Break-Before-Make Time Delay, tBBM 75 ns typ RL = 100 Ω, CL = 35 pF 30 ns min VS1 = VS2 = 8 V; see Figure 31 Rev. C | Page 4 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY 12 V SINGLE SUPPLY ±5 V DUAL SUPPLY CONTINUOUS CURRENT PER CHANNEL ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
