Datasheet ADG1201 (Analog Devices) - 9
ОписаниеLow Capacitance, Low Charge Injection, ±15 V/+12 V iCMOS SPST in SOT-23
Страниц / Страница14 / 9 — Data Sheet. ADG1201. 150. 0.5. DD = +5V. A = 25ºC. 0.4. 100. VSS = –5V. …
ВерсияA
Формат / Размер файлаPDF / 418 Кб
Data Sheet. ADG1201. 150. 0.5. DD = +5V. A = 25ºC. 0.4. 100. VSS = –5V. VBIAS = ±4.5V. 0.3. DD = +15V. SS = –15V. 0.2. (p N. 0.1. RRE. –50. CU E. INJ E
Data Sheet ADG1201 150 0.5 DD = +5V A = 25ºC 0.4 100 VSS = –5V VBIAS = ±4.5V 0.3 DD = +15V SS = –15V 0.2 (p N 0.1 RRE –50 CU E INJ E
36 предложений от 16 поставщиков
ADG1201BRJZ-REEL7
80 ₽
ADG1201BRJZ-REEL7
122 ₽
ADG1201BRJZ-REEL7
228 ₽
ADG1201BRJZ-REEL7
Data Sheet ADG1201 150 0.5 V T DD = +5V A = 25ºC 0.4 100 VSS = –5V VBIAS = ±4.5V V 0.3 DD = +15V V 50 SS = –15V A) C) 0.2 (p (p N NT 0 IO 0.1 RRE CT –50 E 0 CU E INJ E VDD = 12V –100 –0.1 VSS = 0V AKAG E –0.2 L –150 CHARG –0.3 IS (OFF) + – ID (OFF) + – –200
6
I V S (OFF) – + ID (OFF) – + DD = +5V
02
–0.4
022 6-
I V D, IS (ON) + + ID, IS (ON) – – SS = –5V
57 76-
–250
06
–0.5
065
0 20 40 60 80 100 120 –15 –10 –5 0 5 10 15 TEMPERATURE (ºC) SOURCE VOLTAGE (V)
Figure 9. Leakage Currents vs. Temperature, Dual Supply Figure 12. Charge Injection vs. Source Voltage
300 300 V 15V DS tOFF 250 DD = 12V 15V DS t V ON SS = 0V 12V SS t V 250 OFF 200 BIAS = 1/10V 12V SS tON A) 150 s) (p 200 (n NT 100 S E RE IM 50 T 150 CUR F E 0 /t OF t ON 100 AKAG E –50 L –100 50 IS (OFF) + – ID (OFF) + –
3
–150 IS (OFF) – + ID (OFF) – +
-02 027 6-
ID, IS (ON) + + ID, IS (ON) – –
576 57
0
06
–200
06
–40 –20 0 20 40 60 80 100 120 0 20 40 60 80 100 120 TEMPERATURE (ºC) TEMPERATURE (ºC)
Figure 10. Leakage Currents vs. Temperature, Single Supply Figure 13. tON/tOFF Times vs. Temperature
120 0 IDD PER CHANNEL VDD = 15V TA = 25ºC VSS = –15V 100 –20 TA = 25ºC B) 80 –40 (d N ) IO µA ( 60 AT L –60 I DD O V IS DD = +15V F 40 F –80 VSS = –15V O V 20 DD = 12V –100 V
1
SS = 0V
16 0 -02 6 6- 57 657
0
06
–120
0
0 2 4 6 8 10 12 14 10k 100k 1M 10M 100M 1G LOGIC LEVEL, IN (V) FREQUNCY (Hz)
Figure 11. IDD vs. Logic Level, IN Figure 14. Off Isolation vs. Frequency Rev. A | Page 9 of 14 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications Dual Supply Single Supply Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Outline Dimensions Ordering Guide
