Datasheet ADG1433, ADG1434 (Analog Devices) - 5
Описание4 Ω RON, Triple/Quad SPDT ±15 V/+12 V/±5 V iCMOS Switches
Страниц / Страница20 / 5 — Data Sheet. ADG1433/ADG1434. 12 V SINGLE SUPPLY. Table 2. −40°C to. …
ВерсияE
Формат / Размер файлаPDF / 394 Кб
Data Sheet. ADG1433/ADG1434. 12 V SINGLE SUPPLY. Table 2. −40°C to. Parameter. +25°C. +85°C. +125°C1. Unit. Test Conditions/Comments
Data Sheet ADG1433/ADG1434 12 V SINGLE SUPPLY Table 2 −40°C to Parameter +25°C +85°C +125°C1 Unit Test Conditions/Comments
35 предложений от 17 поставщиков
ADG1433YRUZ-REEL7
582 ₽
ADG1433YRUZ-REEL7
688 ₽
ЗУМ-СМД
ADG1433YRUZ-REEL7
LifeElectronics
ADG1433YRUZ-REEL7
link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 14 link to page 14 link to page 14 link to page 14 link to page 14
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 2. −40°C to −40°C to Parameter +25°C +85°C +125°C1 Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 to VDD V On Resistance, RON 6 Ω typ VS = 0 V to 10 V, IS = −10 mA, see Figure 25 8 9.5 11.2 Ω max VDD = 10.8 V, VSS = 0 V On Resistance Match Between 0.55 Ω typ VS = 0 V to 10 V, IS = −10 mA Channels, ΔRON 0.82 0.85 1.1 Ω max On Resistance Flatness, RFLAT(ON) 1.5 Ω typ VS = 0 V to 10 V, IS = −10 mA 2.5 2.5 2.8 Ω max LEAKAGE CURRENTS VDD = 13.2 V Source Off Leakage, IS (Off) ±0.04 nA typ VS = 1 V/10 V, VD = 10 V/1 V, see Figure 26 ±0.3 ±0.6 ±3 nA max Drain Off Leakage, ID (Off) ±0.04 nA typ VS = 1 V/10 V, VD = 10 V/1 V, see Figure 26 ±0.3 ±0.6 ±3 nA max Channel On Leakage, ID, IS (On) ±0.06 nA typ VS = VD = 1 V or 10 V, see Figure 27 ±0.4 ±0.8 ±8 nA max DIGITAL INPUTS Input High Voltage, VIH 2.0 V min Input Low Voltage, VIL 0.8 V max Input Current, IIL or IIH ±0.005 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 4 pF typ DYNAMIC CHARACTERISTICS2 Transition Time, tTRANS 200 ns typ RL = 100 Ω, CL = 35 pF 255 310 350 ns max VS = 8 V, see Figure 28 Break-Before-Make Time Delay, tD 80 ns typ RL = 100 Ω, CL = 35 pF 55 ns min VS1 = VS2 = 8 V, see Figure 29 tON (EN) 210 ns typ RL = 100 Ω, CL = 35 pF 270 320 360 ns max VS = 8 V, see Figure 30 tOFF (EN) 70 ns typ RL = 100 Ω, CL = 35 pF 86 95 105 ns max VS = 8 V, see Figure 30 Charge Injection −10 pC typ VS = 6 V, RS = 0 Ω, CL = 1 nF, see Figure 31 Off Isolation –70 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 32 Channel-to-Channel Crosstalk –70 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 34 −3 dB Bandwidth 135 MHz typ RL = 50 Ω, CL = 5 pF, see Figure 33 Insertion Loss 0.5 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 33 CS (Off) 25 pF typ f = 1 MHz CD (Off) 45 pF typ f = 1 MHz CD, CS (On) 80 pF typ f = 1 MHz POWER REQUIREMENTS VDD = 13.2 V IDD 0.002 µA typ Digital inputs = 0 V or VDD 1 µA max IDD 260 µA typ Digital inputs = 5 V 475 µA max VDD 5/16.5 V min/max VSS = 0 V, GND = 0 V Continuous Current per Channel2 VDD = +10.8 V, VSS = 0 V ADG1433 100 65 40 mA max ADG1434 85 60 35 mA max 1 Temperature range for Y version: −40
C to +125
C. 2 Guaranteed by design, not subject to production test. Rev. E | Page 5 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS REVISION HISTORY SPECIFICATIONS ±15 V DUAL SUPPLY 12 V SINGLE SUPPLY ±5 V DUAL SUPPLY ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
