Datasheet ADG1208, ADG1209 (Analog Devices) - 5
ОписаниеLow Capacitance, 4-/8-Channel, ±15 V/+12 V iCMOS Multiplexers
Страниц / Страница21 / 5 — Data Sheet. ADG1208/ADG1209. SINGLE SUPPLY. Table 2. −40ºC to. Parameter. …
ВерсияE
Формат / Размер файлаPDF / 415 Кб
Data Sheet. ADG1208/ADG1209. SINGLE SUPPLY. Table 2. −40ºC to. Parameter. +25ºC. +85ºC. +125ºC. Unit. Test Conditions/Comments
Data Sheet ADG1208/ADG1209 SINGLE SUPPLY Table 2 −40ºC to Parameter +25ºC +85ºC +125ºC Unit Test Conditions/Comments
33 предложений от 16 поставщиков
ADG1209YCPZ-REEL7
203 ₽
ЧипСити
ADG1209YCPZ-REEL7
334 ₽
ADG1209YCPZ-REEL7
334 ₽
Зенер
Россия и страны ТС
ADG1209YCPZ-REEL7
от 347 ₽
link to page 17 link to page 17 link to page 17 link to page 17 link to page 17 link to page 18 link to page 18 link to page 17 link to page 18 link to page 19 link to page 19 link to page 19 link to page 6
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted. Temperature range is as follows: Y version: –40°C to +125°C.
Table 2. −40ºC to −40ºC to Parameter +25ºC +85ºC +125ºC Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 to VDD V On Resistance, RON 300 Ω typ VS = 0 V to 10 V, IS = −1 mA, see Figure 31 475 567 625 Ω max VDD = 10.8 V, VSS = 0 V On-Resistance Match Between 5 Ω typ VS = 0 V to 10 V, IS = −1 mA Channels, ∆RON 16 26 27 Ω max On-Resistance Flatness, RFLAT (On) 60 Ω typ VS = 3 V/6 V/9 V, IS = −1 mA LEAKAGE CURRENTS VDD = 13.2 V Source Off Leakage, IS (Off) ±0.003 nA typ VS = 1 V/10 V, VD = 10 V/1 V, see Figure 32 ±0.1 ±0.6 ±1 nA max Drain Off Leakage, ID (Off) ±0.003 nA typ VS = 1 V/10 V, VD = 10 V/1 V, see Figure 32 ADG1208 ±0.1 ±0.6 ±1 nA max ADG1209 ±0.1 ±0.6 ±1 nA max Channel On Leakage ID, IS (On) ±0.02 nA typ VS = VD = 1 V or 10 V, see Figure 33 ADG1208 ±0.2 ±0.6 ±1 nA max ADG1209 ±0.2 ±0.6 ±1 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH ±0.001 ±0.1 µA max VIN = VINL or VINH Digital Input Capacitance, CIN 3 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 100 ns typ RL = 300 Ω, CL = 35 pF 170 210 235 VS = 8 V, see Figure 34 tON (EN) 90 ns typ RL = 300 Ω, CL = 35 pF 110 140 160 VS = 8 V, see Figure 36 tOFF (EN) 105 ns typ RL = 300 Ω, CL = 35 pF 130 155 175 VS = 8 V, see Figure 36 Break-Before-Make Time Delay, tBBM 45 ns typ RL = 300 Ω, CL = 35 pF 20 ns min VS1 = VS2 = 8 V, see Figure 35 Charge Injection −0.2 pC typ VS = 6 V, RS = 0 Ω, CL = 1 nF, see Figure 37 Off Isolation −85 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 38 Channel to Channel Crosstalk −85 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 40 −3 dB Bandwidth 450 MHz typ RL = 50 Ω, CL = 5 pF, see Figure 39 CS (Off) 1.2 pF typ f = 1 MHz, VS = 6 V 1.8 pF max f = 1 MHz, VS = 6 V CD (Off), ADG1208 7.5 pF typ f = 1 MHz, VS = 6 V 9 pF max f = 1 MHz, VS = 6 V CD (Off), ADG1209 4.5 pF typ f = 1 MHz, VS = 6 V 5.5 pF max f = 1 MHz, VS = 6 V CD, CS (On), ADG1208 9 pF typ f = 1 MHz, VS = 6 V 10.5 pF max f = 1 MHz, VS = 6 V CD, CS (On), ADG1209 6 pF typ f = 1 MHz, VS = 6 V 7.5 pF max f = 1 MHz, VS = 6 V Rev. E | Page 5 of 21 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
