Datasheet ADG1204 (Analog Devices) - 3
ОписаниеLow Capacitance, Low Charge Injection, ±15 V/+12 V, 4:1 iCMOS Multiplexer
Страниц / Страница16 / 3 — Data Sheet. ADG1204. SPECIFICATIONS DUAL SUPPLY. Table 1. Y Version1. …
ВерсияC
Формат / Размер файлаPDF / 462 Кб
Data Sheet. ADG1204. SPECIFICATIONS DUAL SUPPLY. Table 1. Y Version1. −40°C to. Parameter. 25°C. +85°C. +125°C. Unit
Data Sheet ADG1204 SPECIFICATIONS DUAL SUPPLY Table 1 Y Version1 −40°C to Parameter 25°C +85°C +125°C Unit
58 предложений от 22 поставщиков
ADG1204YRUZ-REEL7
171 ₽
РИВ Электроникс
Россия и страны ТС
ADG1204YRUZ-REEL7
от 262 ₽
ADG1204YRUZ-REEL
275 ₽
Зенер
Россия и страны ТС
ADG1204YRUZ-REEL7
от 291 ₽
link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 13 link to page 13 link to page 13 link to page 13 link to page 13 link to page 4 link to page 4
VDD = 15 V ± 10%, VSS = −15 V ± 10%, GND = 0 V, unless otherwise noted.
Table 1. Y Version1 −40°C to −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VDD to VSS V On Resistance (RON) 120 Ω typ VS = ±10 V, IS = −1 mA; see Figure 21 190 230 260 Ω max VDD = +13.5 V, VSS = −13.5 V On Resistance Match Between 3.5 Ω typ VS = ±10 V, IS = −1 mA Channels (ΔRON) 6 10 12 Ω max On Resistance Flatness (RFLAT(ON)) 20 Ω typ VS = −5 V, 0 V, +5 V; IS = −1 mA 57 72 79 Ω max LEAKAGE CURRENTS VDD = +16.5 V, VSS = −16.5 V Source Off Leakage, IS (OFF) ±0.02 nA typ VS = ±10 V, VD = ∓10 V; see Figure 22 ±0.1 ±0.6 ±1 nA max Drain Off Leakage, ID (OFF) ±0.02 nA typ VS = ±10 V, VD = ∓10 V; see Figure 22 ±0.1 ±0.6 ±1 nA max Channel On Leakage, ID, IS (ON) ±0.02 nA typ VS = VD = ±10 V; see Figure 23 ±0.2 ±0.6 ±1 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or INH 0.005 µA typ VIN = VINL or VINH ±0.1 µA max Digital Input Capacitance, CIN 2.5 pF typ DYNAMIC CHARACTERISTICS2 Transition Time, tTRANS 120 ns typ RL = 300 Ω, CL = 35 pF 150 180 200 ns max VS = 10 V; see Figure 24 tON (EN) 70 ns typ RL = 300 Ω, CL = 35 pF 85 100 110 ns max VS = 10 V; see Figure 26 tOFF (EN) 90 ns typ RL = 300 Ω, CL = 35 pF 110 135 155 ns max VS = 10 V; see Figure 26 Break-Before-Make Time Delay, tD 25 ns typ RL = 300 Ω, CL = 35 pF 10 ns min VS1 = VS2 = 10 V; see Figure 25 Charge Injection −0.7 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 27 Off Isolation 85 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 28 Channel-to-Channel Crosstalk 80 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 30 Total Harmonic Distortion + Noise 0.15 % typ RL = 10 kΩ, 5 V rms, f = 20 Hz to 20 kHz; see Figure 31 Bandwidth −3 dB 800 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 29 CS (OFF) 1.2 pF typ f = 1 MHz, VS = 0 V 1.5 pF max f = 1 MHz, VS = 0 V CD (OFF) 3.6 pF typ f = 1 MHz, VS = 0 V 4.2 pF max f = 1 MHz, VS = 0 V CD, CS (ON) 5.5 pF typ f = 1 MHz, VS = 0 V 6.5 pF max f = 1 MHz, VS = 0 V Rev. C | Page 3 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TRUTH TABLE TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
