Datasheet ADG621 (Analog Devices) - 4
ОписаниеCMOS, ±5 V/+5 V, 4 Ω Dual SPST Switches
Страниц / Страница12 / 4 — ADG621. Data Sheet. SINGLE SUPPLY. Table 2. Parameter. +25°C –40°C to …
ВерсияC
Формат / Размер файлаPDF / 242 Кб
ADG621. Data Sheet. SINGLE SUPPLY. Table 2. Parameter. +25°C –40°C to +85°C. Unit. Test Conditions/Comments
ADG621 Data Sheet SINGLE SUPPLY Table 2 Parameter +25°C –40°C to +85°C Unit Test Conditions/Comments
45 предложений от 22 поставщиков
ADG621BRMZ-REEL
88 ₽
ADG621BRMZ-REEL
141 ₽
ADG621BRMZ
от 400 ₽
Контест
ADG621BRMZ
link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 10 link to page 10 link to page 10
VDD = 5 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 2. Parameter +25°C –40°C to +85°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 to VDD V VDD = 4.5 V, VSS = 0 V On Resistance, RON 7 Ω typ VS = 0 V to 4.5 V, IS = –10 mA, see Figure 14 10 12.5 Ω max On Resistance Match Between Channels, ∆RON 0.5 Ω typ VS = 0 V to 4.5 V, IS = −10 mA 0.75 1 Ω max On Resistance Flatness, RFLAT(ON) 0.5 0.5 Ω typ VS = 1.5 V to 3.3 V, IS = −10 mA 1.2 Ω max LEAKAGE CURRENTS VDD = 5.5 V Source Off Leakage IS (Off) ±0.01 nA typ VS = 1 V/4.5 V, VD = 4.5 V/1 V, see Figure 15 ±0.25 ±1 nA max Drain Off Leakage ID (Off) ±0.01 nA typ VS = 1 V/4.5 V, VD = 4.5 V/1 V, see Figure 15 ±0.25 ±1 nA max Channel On Leakage, ID, IS (On) ±0.01 nA typ VS = VD = 1 V/4.5 V, see Figure 16 ±0.25 ±1 nA max DIGITAL INPUTS Input High Voltage, VINH 2.4 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.005 µA typ VIN = VINL or VINH ±0.1 µA max Digital Input Capacitance, CIN 2 pF typ DYNAMIC CHARACTERISTICS1 tON 120 ns typ RL = 300 Ω, CL = 35 pF; VS = 3.3 V, see Figure 17 210 260 ns max tOFF 50 ns typ RL = 300 Ω, CL = 35 pF; VS = 3.3 V, see Figure 17 75 100 ns max Charge Injection, QINJ 6 pC typ VS = 0 V; RS = 0 Ω, CL = 1 nF, see Figure 18 Off Isolation –65 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 19 Channel-to-Channel Crosstalk –90 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 20 −3 dB Bandwidth 230 MHz typ RL = 50 Ω, CL = 5 pF, see Figure 21 CS (Off) 20 pF typ f = 1 MHz CD (Off) 20 pF typ f = 1 MHz CD, CS (On) 70 pF typ f = 1 MHz POWER REQUIREMENTS2 VDD = 5.5 V IDD 0.001 µA typ Digital Inputs = 0 V or 5.5 V 1.0 µA max 1 Guaranteed by design; not subject to production test. 2 The device is fully specified at ±5 V dual supply and at +5 V single supply only. It is possible to operate the ADG621 with unbalanced supplies or at other voltage supplies (±2.7 V to ±5.5 V dual supply, and +2.7 V to +5.5 V single supply); however, the switch characteristics change. These changes include, but are not limited to, analog signal range, on resistance, leakage, VINL, VINH, and switching times. The optimal power-up sequence for the device is ground, VDD, VSS, and then the digital inputs, before applying the analog input signal. Rev. C | Page 4 of 12 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
