Datasheet ADG714, ADG715 (Analog Devices) - 7
ОписаниеCMOS, Low Voltage Serially Controlled, Octal SPST Switches
Страниц / Страница21 / 7 — Data Sheet. ADG714/. ADG715. Parameter. +25°C. −40°C to +85°C Unit. Test …
ВерсияE
Формат / Размер файлаPDF / 368 Кб
Data Sheet. ADG714/. ADG715. Parameter. +25°C. −40°C to +85°C Unit. Test Conditions/Comments. TIMING CHARACTERISTICS ADG714
Data Sheet ADG714/ ADG715 Parameter +25°C −40°C to +85°C Unit Test Conditions/Comments TIMING CHARACTERISTICS ADG714
62 предложений от 27 поставщиков
Микросхема Чип аналогового переключателя, ANALOG DEVICES ADG714BRUZ Analog Switch, Octal Channel, SPST, 8Channels, 4.5Ω, 2.7V to 5.5V, TSSOP, 24Pins
ADG714BRUZ
129 ₽
Элитан
ADG714BRUZ
244 ₽
727GS
ADG714BRUZ-REEL7
от 448 ₽
LifeElectronics
ADG714BRUZ
link to page 8 link to page 8 link to page 8 link to page 8 link to page 8
Off Switch Source Capacitance, CS (OFF) 11 pF typ Off Switch Drain Capacitance, CD (OFF) 11 pF typ On Switch Capacitance, C D (ON), C S (ON) 22 pF typ POWER REQUIREMENTS VDD = +2.75 V, VSS = −2.75 V Positive Power Supply Current, IDD 15 µA typ Digital inputs = 0 V or VDD 25 µA max Negative Power Supply Current, ISS 15 µA typ 25 µA max
VDD = 2.7 V to 5.5 V. All specifications are from −40°C to +85°C, unless otherwise noted. See Figure 3. All input signals are specified with tR = tF = 5 ns (10% to 90% of VDD) and timed from a voltage level of (VIL + VIH)/2.
Table 4. Parameter Limit at TMIN, TMAX Unit Conditions/Comments
fSCLK 30 MHz max SCLK cycle frequency t1 33 ns min SCLK cycle time t2 13 ns min SCLK high time t3 13 ns min SCLK low time t4 0 ns min SYNC to SCLK rising edge setup time t5 5 ns min Data setup time t6 4.5 ns min Data hold time t7 0 ns min SCLK falling edge to SYNC rising edge t8 33 ns min Minimum SYNC high time t 1 9 20 ns max SCLK rising edge to DOUT valid t10 0 ns min SCLK falling edge to SYNC falling edge t11 6 ns max SYNC rising edge to SCLK rising edge 1 CL = 20 pF, RL = 1 kΩ.
ADG715
VDD = 2.7 V to 5.5 V. All specifications are from −40°C to +85°C, unless otherwise noted. See Figure 4.
Table 5. Parameter Limit at TMIN, TMAX Unit Conditions/Comments
fSCL 400 kHz max SCL clock frequency t1 2.5 µs min SCL cycle time t2 0.6 µs min SCL high time, tHIGH t3 1.3 µs min SCL low time, tLOW t4 0.6 µs min Start/repeated start condition hold time, tHD, STA t5 100 ns min Data setup time, tSU, DAT t 1 6 0.9 µs max Data hold time, tHD, DAT 0 µs min t7 0.6 µs min Setup time for repeated start, tSU, STA t8 0.6 µs min Stop condition setup time, tSU, STO t9 1.3 µs min Bus free time between a stop condition and a start condition, tBUF t10 300 ns max Rise time of both SCL and SDA when receiving, tR 20 + 0.1C 2 b ns min t11 250 ns max Fall time of SDA when receiving, tF t11 300 ns max Fall time of SDA when transmitting, tF 0.1C 2 b ns min Rev. E | Page 7 of 21 Document Outline Features Applications General Description Functional Block Diagrams Product Highlights Revision History Specifications 5 V Single Supply 3 V Single Supply ±2.5 V Dual Supply Timing Characteristics ADG714 ADG715 Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Power-On Reset Serial Interface 3-Wire Serial Interface 2-Wire Serial Interface Input Shift Register Write Operation Read Operation Applications Information Multiple Devices on One Bus Daisy-Chaining Multiple ADG714 Devices Power Supply Sequencing Decoding Multiple ADG714 Devices Using the ADG739 Outline Dimensions Ordering Guide
