Datasheet ADG436 (Analog Devices) - 3
ОписаниеDual SPDT Switch
Страниц / Страница12 / 3 — ADG436. SPECIFICATIONS DUAL SUPPLY1. Table 1. Parameter. +25°C. −40°C to …
ВерсияB
Формат / Размер файлаPDF / 325 Кб
ADG436. SPECIFICATIONS DUAL SUPPLY1. Table 1. Parameter. +25°C. −40°C to +85°C. Unit. Test Conditions/ Comments
ADG436 SPECIFICATIONS DUAL SUPPLY1 Table 1 Parameter +25°C −40°C to +85°C Unit Test Conditions/ Comments
37 предложений от 19 поставщиков
Микросхема Чип аналогового переключателя, ANALOG DEVICES ADG436BNZ Analog Switch, Dual Channel, SPDT, 2Channels, 25Ω, 3V to 30V, DIP, 16Pins
ADG436BNZ
от 148 ₽
ADG436BNZ
185 ₽
ADG436BNZ
Hi-Tech Circuit Group
ADG436BNZ
link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 3 link to page 4
VDD = +15 V, VSS = −15 V, GND = 0 V, unless otherwise noted.
Table 1. Parameter +25°C −40°C to +85°C Unit Test Conditions/ Comments
ANALOG SWITCH Analog Signal Range VSS to VDD V RON 12 Ω typ VD = ±10 V, IS = −1 mA 25 Ω max ∆RON 1 Ω typ VD = −5 V, 5 V, IS = −10 mA 3 Ω max RONMatch 1 Ω typ VD = ±10 V, IS = −10 mA 2.5 Ω max LEAKAGE CURRENTS VDD = 16.5 V, VSS = −16.5 V Source OFF Leakage IS (OFF) ±0.005 nA typ VD = ±15.5 V, VS = ±15.5 V ±0.25 ±5 nA max Figure 13 Channel ON Leakage ID, IS (ON) ±0.05 nA typ VS = VD = ±15.5 V ±0.4 ±5 nA max Figure 14 DIGITAL INPUTS Input High Voltage, VINH 2.4 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH ±0.005 µA typ VIN = 0 V or VDD ±0.5 µA max DYNAMIC CHARACTERISTICS2 tON 70 ns typ RL = 300 Ω , CL = 35 pF; 125 ns max VS =±10 V; Figure 15 tOFF 60 ns typ RL = 300 Ω , CL = 35 pF; 120 ns max VS = ±10 V; Figure 15 Break-Before-Make Delay, tOPEN 10 ns min RL = 300 Ω , CL = 35 pF; VS = +5 V; Figure 16 Charge Injection 10 pC typ VD = 0 V, RD = 0 Ω, CL = 10 nF; Figure 17 OFF Isolation 72 dB typ RL = 75 Ω , CL = 5 pF, f = 1 MHz; VS = 2.3 V rms, Figure 18 Channel-to-Channel Crosstalk 90 dB typ RL = 75 Ω, CL = 5 pF, f = 1 MHz; VS = 2.3 V rms, Figure 19 CS (OFF) 13 pF typ CD, CS (ON) 49 pF typ POWER REQUIREMENTS IDD 0.05 mA typ Digital inputs = 0 V or 5 V 0.35 mA max ISS 0.01 µA typ 1 5 µA max VDD/VSS ±3/±20 V min/V max |VDD| = |VSS| 1 Temperature range is as follows: B version, −40°C to +85°C. 2 Guaranteed by design; not subject to production test. Rev. B | Page 3 of 12 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS APPLICATIONS INFORMATION ADG436 SUPPLY VOLTAGES POWER-SUPPLY SEQUENCING OUTLINE DIMENSIONS ORDERING GUIDE
