Datasheet ADG528F (Analog Devices) - 6
Описание8-Channel Fault-Protected Analog Multiplexer
Страниц / Страница16 / 6 — ADG528F. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter Rating. ESD CAUTION
ВерсияF
Формат / Размер файлаPDF / 287 Кб
ADG528F ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Rating ESD CAUTION
36 предложений от 18 поставщиков
ADG528FBPZ
от 2 112 ₽
Элитан
ADG528FBPZ
2 277 ₽
ADG528FBPZ
ADG528FBPZ
T Stresses above those listed under Absolute Maximum Ratings A = 25°C unless otherwise noted. may cause permanent damage to the device. This is a stress
Table 3.
rating only; functional operation of the device at these or any
Parameter Rating
other conditions above those indicated in the operational VDD to VSS 44 V section of this specification is not implied. Exposure to absolute VDD to GND −0.3 V to +25 V maximum rating conditions for extended periods may affect VSS to GND +0.3 V to −25 V device reliability. Digital Input, EN, Ax −0.3 V to VDD + 2 V or 20 mA, whichever occurs first VS, Analog Input Overvoltage with VSS − 25 V to VDD + 40 V
ESD CAUTION
Power On (VDD = +15 V, VSS = −15 V) VS, Analog Input Overvoltage with −40 V to +55 V Power Off (VDD = 0 V, VSS = 0 V) Continuous Current, S or D 20 mA Peak Current, S or D (Pulsed at 1 ms, 10% Duty Cycle Max) 40 mA Operating Temperature Range Industrial (B Version) −40°C to +85°C Storage Temperature Range −65°C to +150°C Junction Temperature 150°C θJA, Thermal Impedance 90°C/W Lead Temperature, Soldering Vapor Phase (60 sec) 215°C Infrared (15 sec) 220°C Rev. F | Page 6 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY TRUTH TABLE TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
