Datasheet ADG419 (Analog Devices) - 4
ОписаниеLC2MOS Precision Mini-DIP Analog Switch
Страниц / Страница16 / 4 — ADG419. SINGLE SUPPLY. Table 2. B Version. T Version. −40°C to. −55°C to. …
ВерсияB
Формат / Размер файлаPDF / 319 Кб
ADG419. SINGLE SUPPLY. Table 2. B Version. T Version. −40°C to. −55°C to. Parameter1. +25°C. +85°C. +125°C +25°C. +125°C. Unit
ADG419 SINGLE SUPPLY Table 2 B Version T Version −40°C to −55°C to Parameter1 +25°C +85°C +125°C +25°C +125°C Unit
70 предложений от 29 поставщиков
ADG419BRMZ-REEL
от 62 ₽
ADG419BRMZ
103 ₽
Зенер
Россия и страны ТС
ADG419BRMZ-REEL7
от 213 ₽
727GS
ADG419BRMZ-REEL7
link to page 4 link to page 9 link to page 9 link to page 9 link to page 4 link to page 9 link to page 9 link to page 10 link to page 10
VDD = 12 V ± 10%, VSS = 0 V, VL = 5 V ± 10%, GND = 0 V, unless otherwise noted.
Table 2. B Version T Version −40°C to −40°C to −55°C to Parameter1 +25°C +85°C +125°C +25°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 to VDD 0 to VDD V RON 40 40 Ω typ VD = 3 V, 8.5 V, IS = −10 mA 60 70 70 Ω max VDD = 10.8 V LEAKAGE CURRENT VDD = 13.2 V Source OFF Leakage, IS (Off ) ±0.1 ±0.1 nA typ VD = 12.2 V/1 V, VS = 1 V/12.2 V; see Figure 12 ±0.25 ±5 ±15 ±0.25 ±15 nA max Drain OFF Leakage, ID (Off ) ±0.1 ±0.1 nA typ VD = 12.2 V/1 V, VS = 1 V/12.2 V; see Figure 12 ±0.75 ±5 ±30 ±0.75 ±30 nA max Channel ON Leakage, ID, IS (On) ±0.4 ±0.4 nA typ VS = VD = 12.2 V/1 V; see Figure 13 ±0.75 ±5 ±30 ±0.75 ±30 nA max DIGITAL INPUTS Input High Voltage, VINH 2.4 2.4 2.4 V min Input Low Voltage, VINL 0.8 0.8 0.8 V max Input Current IINL or IINH ±0.005 ±0.005 ±0.005 μA typ VIN = VINL or VINH ±0.5 ±0.5 ±0.5 μA max DYNAMIC CHARACTERISTICS2 tTRANSITION 180 250 250 170 250 ns max RL = 300 Ω, CL = 35 pF; VS1 = 0 V/8 V, VS2 = 8 V/0 V; see Figure 14 Break-Before-Make Time Delay, tD 60 60 ns typ RL = 300 Ω, CL = 35 pF; VS1 = VS2 = 8 V; see Figure 15 Off Isolation 80 80 dB typ RL = 50 Ω, f = 1 MHz; see Figure 16 Channel-to-Channel Crosstalk 90 70 dB typ RL = 50 Ω, f = 1 MHz; see Figure 17 CS (Off ) 13 13 pF typ f = 1 MHz CD, CS (On) 65 65 pF typ f = 1 MHz POWER REQUIREMENTS VDD = 13.2 V IDD 0.0001 0.0001 μA typ VIN = 0 V or 5 V 1 2.5 2.5 1 2.5 μA max IL 0.0001 0.0001 μA typ VL = 5.5 V 1 2.5 2.5 1 2.5 μA max 1 Temperature ranges are as follows: B Version: −40°C to +125°C; T Version: −55°C to +125°C. 2 Guaranteed by design, not subject to production test. Rev. B | Page 4 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
