Datasheet ADG431, ADG432, ADG433 (Analog Devices) - 3
ОписаниеLC2MOS Precision Quad SPST Switch
Страниц / Страница8 / 3 — ADG431/ADG432/ADG433. Single Supply (VDD = 12 V. 10%, VSS = O V, VL = 5 …
ВерсияC
Формат / Размер файлаPDF / 135 Кб
ADG431/ADG432/ADG433. Single Supply (VDD = 12 V. 10%, VSS = O V, VL = 5 V. 10%, GND = O V, unless otherwise noted). B Version
ADG431/ADG432/ADG433 Single Supply (VDD = 12 V 10%, VSS = O V, VL = 5 V 10%, GND = O V, unless otherwise noted) B Version
70 предложений от 28 поставщиков
ICdarom.ru
ADG433BRZ-REEL AD SOIC16
от 361 ₽
Эиком
ADG433BRZ-REEL
от 785 ₽
ADG433BRZ
844 ₽
ADG433BRZ
ADG431/ADG432/ADG433 Single Supply (VDD = 12 V 10%, VSS = O V, VL = 5 V 10%, GND = O V, unless otherwise noted) B Version –40 C to Parameter +25 C +85 C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V RON 28 Ω typ 0 < VD < 8.5 V, IS = –10 mA; 42 45 Ω max VDD = 10.8 V RON vs. VD (VS) 20 % typ RON Drift 0.5 %/°C typ RON Match 5 % typ VD = 0 V, IS = –10 mA LEAKAGE CURRENTS VDD = 13.2 V Source OFF Leakage IS (OFF) ±0.04 nA typ VD = 12.2/1 V, VS = 1/12.2 V; ±0.25 ±2 nA max Test Circuit 2 Drain OFF Leakage ID (OFF) ±0.04 nA typ VD = 12.2/1 V, VS = 1/12.2 V; ±0.25 ±2 nA max Test Circuit 2 Channel ON Leakage ID, Is (ON) ±0.01 nA typ VD = VS = 12.2 V/1 V; ±0.3 ±3 nA max Test Circuit 3 DIGITAL INPUTS Input High Voltage, VINH 2.4 V min Input Low Voltage, VINL 0.8 V max Input Current IINL or IINH 0.005 µA typ VIN = VINL or VINH ±0.01 µA max CIN Digital Input Capacitance 9 pF typ DYNAMIC CHARACTERISTICS1 VDD = 12 V, VSS = 0 V tON 165 ns typ RL = 300 Ω, CL = 35 pF; 240 ns max VS = 8 V; Test Circuit 4 tOFF 60 ns typ RL = 300 Ω, CL = 35 pF; 115 ns max VS = 8 V; Test Circuit 4 Break-Before-Make Time Delay, tD 25 ns typ RL = 300 Ω, CL = 35 pF; (ADG433 Only) VS1 = VS2 = 10 V; Test Circuit 5 Charge Injection 25 pC typ VS = 0 V, RS = 0 Ω, CL = 10 nF; Test Circuit 6 OFF Isolation 68 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; Test Circuit 7 Channel-to-Channel Crosstalk 85 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; Test Circuit 8 CS (OFF) 9 pF typ f = 1 MHz CD (OFF) 9 pF typ f = 1 MHz CD, CS (ON) 35 pF typ f = 1 MHz POWER REQUIREMENTS VDD = 13.2 V Digital Inputs = 0 V or 5 V IDD 0.0001 µA typ 0.03 0.1 µA max IL 0.0001 µA typ 0.03 0.1 µA max VL = 5.25 V Power Dissipation 1.9 µW max NOTES 1Guaranteed by design, not subject to production test. Specifications subject to change without notice.
Truth Table (ADG431/ADG432) Truth Table (ADG433) ADG431 In ADG432 In Switch Condition Logic Switch 1, 4 Switch 2, 3
0 1 ON 0 OFF ON 1 0 OFF 1 ON OFF REV. C –3–
