Datasheet ADG411, ADG412, ADG413 (Analog Devices) - 3
ОписаниеLC2MOS Precision Quad SPST Switches
Страниц / Страница16 / 3 — ADG411/ADG412/ADG413. SPECIFICATIONS DUAL SUPPLY. Table 1. B Version. T …
ВерсияD
Формат / Размер файлаPDF / 222 Кб
ADG411/ADG412/ADG413. SPECIFICATIONS DUAL SUPPLY. Table 1. B Version. T Version. −40°C to. −55°C to. Parameter +25°C. +85°C +25°C. +125°C
ADG411/ADG412/ADG413 SPECIFICATIONS DUAL SUPPLY Table 1 B Version T Version −40°C to −55°C to Parameter +25°C +85°C +25°C +125°C
48 предложений от 19 поставщиков
ICdarom.ru
ADG412BRUZ-REEL7
от 567 ₽
Эиком
ADG412BRUZ-REEL7
от 794 ₽
TradeElectronics
ADG412BRUZ-REEL7
ADG412BRUZ-REEL7
link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 12 link to page 12 link to page 3 link to page 3
VDD = 15 V ± 10%, VSS = –15 V ± 10%, VL = 5 V ± 10%, GND = 0 V, unless otherwise noted.1
Table 1. B Version T Version −40°C to −55°C to Parameter +25°C +85°C +25°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VDD to VSS VDD to VSS V RON 25 25 Ω typ VD = ±8.5 V, IS = −10 mA; 35 45 35 45 Ω max VDD = +13.5 V, VSS = −13.5 V LEAKAGE CURRENTS VDD = +16.5 V, VSS = −16.5 V Source OFF Leakage IS (OFF) ±0.1 ±0.1 nA typ VD = +15.5 V/−15.5 V, VS = −15.5 V/+15.5 V; ±0.25 ±0.25 ±0.25 ±20 nA max Figure 15 Drain OFF Leakage ID (OFF) ±0.1 ±0.1 nA typ VD = +15.5 V/−15.5 V, VS = −15.5 V/+15.5 V; ±0.25 ±5 ±0.25 ±20 nA max Figure 15 Channel ON Leakage ID, IS (ON) ±0.1 ±0.1 nA typ VD = VS = +15.5 V/−15.5 V; ±0.4 ±10 ±0.4 ± 40 nA max Figure 16 DIGITAL INPUTS Input High Voltage, VINH 2.4 2.4 V min Input Low Voltage, VINL 0.8 0.8 V max Input Current IINL or IINH 0.005 0.005 μA typ VIN = VINL or VINH ±0.5 ±0.5 μA max DYNAMIC CHARACTERISTICS2 tON 110 110 ns typ RL = 300 Ω, CL = 35 pF; 175 175 ns max VS = ±10 V; Figure 17 tOFF 100 100 ns typ RL = 300 Ω, CL = 35 pF; 145 145 ns max VS = ±10 V; Figure 17 Break-Before-Make Time Delay, tD 25 25 ns typ RL = 300 Ω, CL = 35 pF; (ADG413 Only) VS1 = VS2 = 10 V; Figure 18 Charge Injection 5 5 pC typ VS = 0 V, RS = 0 Ω, CL = 10 nF; Figure 19 OFF Isolation 68 68 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; Figure 20 Channel-to-Channel Crosstalk 85 85 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; Figure 21 CS (OFF) 9 9 pF typ f = 1 MHz CD (OFF) 9 9 pF typ f = 1 MHz CD, CS (ON) 35 35 pF typ f = 1 MHz POWER REQUIREMENTS VDD = +16.5 V, VSS = −16.5 V; Digital inputs = 0 V or 5 V IDD 0.0001 0.0001 μA typ 1 5 1 5 μA max ISS 0.0001 0.0001 μA typ 1 5 1 5 μA max IL 0.0001 0.0001 μA typ 1 5 1 5 μA max 1 Temperature ranges are as follows: B versions: −40°C to +85°C; T versions: −55°C to +125°C. 2 Guaranteed by design; not subject to production test. Rev. D | Page 3 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS FUNCTIONAL BLOCK DIAGRAMS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY APPLICATIONS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
