Клеммники KEEN SIDE
Datasheet ADG824 (Analog Devices) - 4
Описание0.5 Ω CMOS 1.65 V to 3.6 V Dual SPDT/2:1 Mux in Mini LFCSP Package
Страниц / Страница16 / 4 — ADG824. Data Sheet. Table 2. Parameter. +25°C. −40°C to +85°C. Unit. Test …
ВерсияC
Формат / Размер файлаPDF / 243 Кб
ADG824. Data Sheet. Table 2. Parameter. +25°C. −40°C to +85°C. Unit. Test Conditions/Comments
ADG824 Data Sheet Table 2 Parameter +25°C −40°C to +85°C Unit Test Conditions/Comments
36 предложений от 15 поставщиков
Микросхема Чип аналогового переключателя, ANALOG DEVICES ADG824BCPZ-REEL7 Analogue Switch, Dual Channel, SPDT, 2Channels, 0.8Ω, 1.65V to 3.6V, LFCSP, 10Pins
Зенер
Россия и страны ТС
ADG824BCPZ-REEL7
от 106 ₽
ADG824BCPZ-REEL7
401 ₽
727GS
ADG824BCPZ-REEL7
ТаймЧипс
ADG824BCPZ-REEL7
link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 6 link to page 4
ADG824 Data Sheet
VDD = 2.5 V ± 0.2 V, GND = 0 V, unless otherwise noted.
Table 2. Parameter +25°C −40°C to +85°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 to VDD V On Resistance, RON 0.65 Ω typ VDD = 2.3 V, VS = 0 V to VDD, IDS = 100 mA; see Figure 19 0.95 1.0 Ω max On Resistance Match Between 0.005 Ω typ VDD = 2.3 V, VS = 0.7 V, IDS = 100 mA Channels, ∆RON 0.04 Ω max On Resistance Flatness, RFLAT (ON) 0.2 Ω typ VDD = 2.3 V, VS = 0 V to VDD, IDS = 100 mA 0.35 Ω max LEAKAGE CURRENTS VDD = 2.7 V Source Off Leakage, IS (Off) ±0.2 nA typ VS = 0.6 V/2.4 V, VD = 2.4 V/0.6 V; see Figure 20 Channel On Leakage, ID, IS (On) ±0.2 nA typ VS = VD = 0.6 V or 2.4 V; see Figure 21 DIGITAL INPUTS Input High Voltage, VINH 1.3 V min Input Low Voltage, VINL 0.7 V max Input Current IINL or IINH 0.005 µA typ VIN = VGND or VDD ±0.1 µA max VIN = VGND or VDD Digital Input Capacitance, CIN 2.7 pF typ DYNAMIC CHARACTERISTICS1 tON 9 ns typ RL = 50 Ω, CL = 35 pF 11.5 12.4 ns max VS = 1.5 V/0 V; see Figure 22 tOFF 6 ns typ RL = 50 Ω, CL = 35 pF 7.4 8 ns max VS = 1.5 V; see Figure 22 Break-Before-Make Time Delay, tBBM 5 ns typ RL = 50 Ω, CL = 35 pF 3 ns min VS1 = VS2 = 1.5 V; see Figure 23 Charge Injection, QINJ 21 pC typ VS = 1.5 V, RS = 0 Ω, CL = 1 nF; see Figure 24 Off Isolation −71 dB typ RL = 50 Ω, CL = 5 pF, f = 100 kHz; see Figure 25 Channel-to-Channel Crosstalk −90 dB typ S1A to S2A/S1B to S2B, RL = 50 Ω, CL = 5 pF, f = 100 kHz; see Figure 26 −71 dB typ S1A to S1B/S2A to S2B, RL = 50 Ω, CL = 5 pF, f = 100 kHz; see Figure 27 Total Harmonic Distortion, THD + N 0.1 % RL = 33 Ω, f = 20 Hz to 20 kHz, VS = 1.5 V p-p Insertion Loss −0.065 dB typ RL = 50 Ω, CL = 5 pF; see Figure 28 –3 dB Bandwidth 90 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 28 CS (Off) 25 pF typ CD, CS (On) 60 pF typ POWER REQUIREMENTS VDD = 2.7 V IDD 0.003 µA typ Digital inputs = 0 V or 2.7 V 1 µA max 1 Guaranteed by design; not subject to production test. Rev. C | Page 4 of 16 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Outline Dimensions Ordering Guide
