Datasheet LXHL (Lumileds) - 2
ПроизводительLumileds
ОписаниеPower Light Source
Страниц / Страница19 / 2 — Mechanical Dimensions. Batwing. Lambertian
Формат / Размер файлаPDF / 984 Кб
Mechanical Dimensions Batwing Lambertian
6 предложений от 6 поставщиков
High Brightness LEDs; LED Color: Green; Forward Current: 350mA; Forward Voltage: 3.42V; Color: Green; Luminous Flux:...
LXHL-DM01
LXHL-DM01-LF
LXHL-DM01
Lumileds
LXHL-DM01
Drawings not to scale Notes: 1. The anode side of the device is denoted by a hole in the lead frame. Electrical insulation between the case and the board is required—slug of device is not electrically neutral. Do not electrically connect either the anode or cathode to the slug. 2. All dimensions are in millimeters. 3. All dimensions without tolerances are for reference only.
Lambertian
Drawings not to scale Notes: 1. The anode side of the device is denoted by a hole in the lead frame. Electrical insulation between the case and the board is required—slug of device is not electrically neutral. Do not electrically connect either the anode or cathode to the slug. 2. All dimensions are in millimeters. 3. All dimensions without tolerances are for reference only. LUXEON Emitter DS25 (5/07) 2
